idbl_fanatic
Ok, I must be missing something, I don't see ANY of my zip files under the recovery, is there a folder we should put them in?
just under the root of your SD card
Do a google search for this
aospCMod -VM670 -20110601 -
signed. zip
It will take you to the download page for the file you want. The 0601 build had the mms fixed.
Sounds like you aren't booting into recovery just trying a reboot. You are holding down the volume up or down key plus the home and power buttons correct?
Got it to reboot into recovery. I tried one last 3 finger salute and it actually worked this time. Go figure.
Thanks for the help. I appreciate the quick response.
This ROM by AOSP is old. Get the new one via ROM Manager. You gotta have ClockWork though...
I was just using this ROM.
Main problems:
Black screen after calls
No receiving MMS
Constant reboots (I have no clue why. My Optimus V is brand new, barely a week old)
Laggy at times
Mms is fine and no random revolts you must be clocked too high or are using the SD card that came.with.the phone Which is no good it made my.phone reboot on stock
Sent from my Optimus V
hmmmm k. so, the rom is great. i love it. 'cept.... the screen rotation. when the phone is freshly booted, it rotates quick. i mean REAL quick. it's great, very responsive. but, after a couple hours it starts to slow down. and by the end of the day it will take about 5 seconds for the screen to rotate.
anybody else have this "problem"?
