jmel
is that 50000 or 500000?
50,000
50k
fifty thousand.
Let me be clear though, I was merely mentioning how I have setcpu set up.
50,000
50k
fifty thousand.
Display will usually be the highest. Android 2.3.2 is pretty good at managing its processes. If you calibrate your battery a few times, any 2.3 rom will be pretty much the same.Not sure if its a problem or not, but has anyone checked the battery usage stats yet? Since installing and running the rom it shows "Display" as the highest use of my battery, averaging 60%. It used to be "Cell Standby" at 40-50% on average.
*Also, does anyone else's batter warm up a bit while charging?
Ah ok. That's good to know. Also, I'm guessing maybe someone else has noticed, but it seems you can't use a wired headset for phone calls with the current build of this ROM. Also wireless tethering through power control doesn't activate it. It shows an error if you look in the settings menu.
Yeah wireless tether native is borked. Download wireless tether from the market, that works. Not sure about headset as I don't use one. There is another build coming aosp said though. Hopefully fixes up some things.
Yeah I'm running wireless tether now. For a first build for our phones, it works pretty good. Any news on a new build?
The ClockworkMod Recovery 3.0.0.6 is nice. If you're unfamiliar with it, it requires Edify only scripting. So all older scripting (Amend) will not work.
Is there an Edify only version of the following file (needed to format /system fully)? It's called "Debug-FormatSYSTEM.zip" and is available at http://dl.dropbox.com/u/21349886/Debug-FormatSYSTEM.zip (and to give credit, comes from the zephie/icemank thread on xionia on Optimus V).
Thanks for pointing me in the right direction.
Any idea why I get "E: Can't open /sdcard/gapps-gb-20110120-signed.zip (bad) Installation aborted." when I try to install gapps with clockwork? Already checked and the md5 matches.
So what kind of changes are in this new build? I dont see any info anywhere yet. MMS working?
