Hello, Does this new updated 20110326 Rom have MMS working now? In Romrepo it's marked as yes. Can anyone confirm?
I successfully sent about 10 MMS messages using GO SMS over the last 3 days.
Havent received any, but i got confirmation that the ones I sent worked
I would be the first on to say it's impossible to get more than 24 hours on a single charge on this rom, but I have achieved it. I'm going 12th hours with 76% with moderate to heavy use. My secret? Use Tasker to disable 3G once screen is off and to turn it back on when screen is unlocked. I don't have it set to turn on when screen turns on because sometimes I turn my screen on to check the time. So that would be pointless. Try it guys.
[ Sent from an LG Optimus V ]
As some have noticed this Rom drains the heck out of the battery in WiFi. My phone gets pretty hot too. I know its normal to warm up but the drain is pretty fast. I go from 100% to 90% in 30-40 mins of WiFi regardless if I am downloading or surfing, it just has to be on. I hope some fix comes out for this because 2.2 wasnt that bad.
It's odd too because having Wifi turn off when screen shuts off is a built in Android feature and it shouldn't eat up the battery. It should mirror what disabling 3G does... to an extent. Odd! :-\
You can off 3G with power control widget or notification widget as well. Data on in bad service area = death of battery.
