ashton4life
Question....I have the previous rom and was wondering what I need to do to get the same black menu and icons on top if I decide to install this one?
BUMP
Anyone having trouble streaming audio? MLB at bat and a few other internet radio apps won't work. Might be network issue for me but just wanted to check here before I reflash everything.
I received a a top up MMS on this rom today and it worked fine. Is that an anomaly or a known non-issue related to the VM MMS encryption?
is the 999999999 error only for MMS?
Do you mean a SMS? I just got the phone and am not sure but I would think top up reminders come in SMS format not MMS right?
I cannot see my favorite plugin on Android - where is it!?
1. Within your Plex Media Server go to Preferences/Advanced and check the box that says 'Disable Capabiliy Checking'.
2. Restart the application - on Android you may need to kill or power cycle the device.
3. Startup Plex for Android - they should now be in Plex Online if you've not yet installed them - you may do so now.
4. After they're installed you will find plugins in 'Video Plugins', 'Photo Plugins', or 'Music Plugins' from the root menu.
If someone has time can u please pm me, I am having nothing but trouble installing this, it constantly freezes at the android start up sign
My battery life only "looks" bad. The phone will drop to 50% battery within 2 hours of being off the charger but after 50% it drops extremely slow. I use the phone heavy for text web Facebook chat and the girl friend grabs it as soon as I set it down to play angry birds and I'm still getting 10-12 hours on this build. I have not done anything to it other then the 50% time without a signal fix and a reboot once a day. (Usually right after shutting off the alarm in the morn and before I get in the shower. Something I got used to dealing with on the hero.)
Sent from my VM670 using Tapatalk
