00_wrath_00
seems exactly the same as the last build, maybe a little smoother?
anyone know of any bug fixes or differences?
I noticed a notification bar tweek and runs smoother
With the 4/27 build and previous builds, my phone only rings once and then doesn't ring anymore for an incoming call. Is there anyway I can fix this?
This has already been discussed somewhere in here. It's not the 4/27 build. It's because there are doubles of the ringtones in the folders. Delete one of each and they'll work fine.
suHi, can anyone tell me what the *.img file is for? I know what to do with zips, but not sure how to utilize that aospCWMod-OV-20110427.img file. Thanks in advance.
What notification bar tweek? I can't find anything different (maybe my settings aren't showing it).
I'm not seeing more than one of each ringtone file ".ogg". I'm in [system/media/audio/...], don't know if this is the right directory to be looking in.
LOCATION SERVICES WORKING (gps off) !!! Now everything is working!
MAKE FULL BACKUP of STOCK ROM FIRST!!!maybe I am a complete idiot... can someone explain in idiot terms for me the process of going from the 4/15 to the 4/27? I would love not to start over but will if necessary. thanks so much
Sent from my VM670 using Tapatalk
Really?
How about :
1. headphone music
2. bluetooth
3. Battery life
I use to use zephies cm7 debug.zip on his recov, does it work effectively on clockworkmod recov? Essentialy debug.zip formats your system/data/boot/cache. I know this would be quicker than manually going through all of the prompts to format each part manually.MAKE FULL BACKUP of STOCK ROM FIRST!!!
make a back up of your user apps using titanium pro(optional). take the aospcwmodrecovery.img and place it on the root of your sdcard, be sure there is the flash_image file the root of your sdcard also..then using terminal emulator punch in
su
flash_image recovery /sdcard/(revovery.img name)
after done flashing boot into recovery to be sure it flashed correctly..now go ahead and put the debug.zip from zephies cm7 thread on the root of your sdcard then put gapps.zip and aospcmod427.zip on your sdcard
then boot into recovery, install the debug.zip, then wipe data/factory resest, go to advanced and wiped dalvik cache, then wipe battery stats if u want...then install aospcmod.zip, then install the gapps. reboot. your done
