00_wrath_00
Wow, I always thought the LG style wipe would brick my phone. I guess ill try that. I always make backups and I did them when I got this ROM to work. But only the first boot works. If I turn my phone off to for whatever reason, including to make a backup it will never start again. Even if I tried to restore using a backup of this ROM" it would just loop. I figured that out and just never turned it off, but then I have the other problem where the ROm would freeze and reboot by itself.
I'm not sure if it will on the xionia.4 version as I'm running xionia.6. But I do the factory reset through recovery only. If you do it through android it will brick with a custom rom. Just to be safe look into the lg style rest before you try because I don't wanna give u bad info and ur phone bricks. Maybe flash the xionia. 6 recovery. Works great for me on all roms here.
Sent from my VM670 using Tapatalk
