quick question. i noticed that i see many comments from people that use this ROM that they overclock with SetCPU. i'm just curious as to why since under the ROM's settings, you can do the same thing. or is there something that SetCPU or the other overclock apps do better than the aospcm7 performance settings?
I use nofrills cpu its free on the market. 844/245 ondemand. every chip is different so find where your phone is stable. CMParts cpu control pretty much does the same thing as no frill's. I prefer no frill's because if it senses a reboot it wont apply on boot....saving you from bootloops. as for apps you can do various things, increase VMHeap, compcache (not available on...yet but will be
) You can also turn off animations.
Here are my CM performance settings:
Jit on
Surface dithering off
purge assets on
home in memory on
messaging in memory on
vm heap = 32m
A lot depends on the kernel...which aosp may or may not be working on
BFS tweaks will get you on average 15-20 more FPS. Compcache will get you swap. etc etc.
Next update will be a good one.
