defcon545
Active member
well, I took my battery out and it still didn't reboot, I will wait it out a bit longer, thanks, been 10 min now
Yeah, wait a bit, if that dosent work try wiping and re-flashing, thats all i can think of right now..
Is it just me, or did this new release bring back the terrible battery issue?
yea, I cant even get into recovery mode, it's just stuck on the android screen, i usually just hold down power button and reboot into recovery mode, but holding down power button doesnt do anything now.I had my phone all day today on the new release, it seems like normal, i leave at 6:30 am ish (PST), and right now its at 23% so im not really noticing a difference.
Zatler: Wipe Cache and Dalvik Cache, and flash the zip again
Have you tried powering down, and pressing Vol Down+Home+Power?
Edit: You let go of them when the splash screen comes up, i think
Yea, I did that, still stuck, nothing happens
So does anyone have a fix for the clock that doesn't require me to reflash 2.3.3, copy the old deskclock.apk, then flash 2.3.4, and then install it?
Why do u use lookout? You honestly don't need it. It just takes up CPU.
As mentioned installing lookout for the locating features alone is worth it.
Plan B is nice but recently on reddit somebody lost their phone and used plan b.
It narrowed it to a eight block radious of his house.
Plan B doesnt allow you to make your phone yelp.
Lookout does.
Does anyone else have issues with Lookout Mobile Security?
On my phone the alarm wont activate until I open the app manually or it also activates the alarm after reboot.
I just wanted to check first before I contact Lookout support as it may be a ROM issue.
Sent from my Optimus V using Tapatalk
