munkyvirus
Couple new things in the Cyanogen settings menu and camera and clock have been rolled back. I think that's it.
everything works now..camera..video..and alarm
Note, the camera does work. But the zoom is back to .1-.5, instead of the 1-5. No biggie, as I rarely use zoom.
Is there anyway to fix the missing character issue?
Usually every build includes a Sync with the CM trees. So whatever CM has added usually is included. Permissions is pretty sweet...you can adjust what apps are allowed to do..i.e. access network etc. Which could cause some apps to not work properly but still pretty neat feature. Kind of like droidwall but built in. If you enable it...then go to manage applications you see the permissions it has. Tapping them turns certain ones off. Don't report bugs on it though because you're changing the natural apps state.This is more them a bug fix update. This update has added more things mostly in the CyanogenMod settings menu. Here is wut I have found....In input settings under buttons "Volume rocker wake"....also in Lockscreen settings under Style options "Incoming call style"....and last In CyanogenMod setting all the way at the bottom "Permissions"(wut is this for?) Well I hope this help you all out. Post new things as you find them
Keep the feedback coming fellas you guys are doing a great job I'm busy working on a new kernel for the rom and audio bugs are still my priority stable is my goal so no worries
