Oh data outage. Ok thanks!
Thats odd, I'm on RebornROM and I have data...
I've done a factory reset with the AOSP mod and it didn't mess anything up (DO NOT DO THIS), I had Data with both the AOSP ROM and now with the Bumblebee ROM. If you some how change your baseband then your screwed, any one ever own a Samsung Intercept?
I flashed the newest version of this rom from manager. Did a full wipe first and for some reason couldn't get the gapps to work...no market app. Any one else? Yes I tried multiple times and still had same results.
Sent from my VM670 using Tapatalk
Tried the Xionia 014 anyKernel, broke the camera, back to aospCM7's kernel, camera works.
Jerry, does your camera auto focus or is it just set on a fixed focus? Can you take a sharp picture of a bar code from 3" away?
to make gapps work. You do need to flash them too. They are not part of the ROM. It is separate file. You can find it in OP of this thread.
Guess there's an update on rom manager 20110601. Is mms broken in 531?
Rom manager was added as a system file kind of dumb when we are not fully supported.
