shawayne21
You have to say skip past that part...all of them do it the first time you access them.
Yes. You're supposed to skip it, then try going into the market where it tells you to sign in, and you sign in.
Camera works in the latest version
I followed the instructions to download the roms from Rom Manager, installed the 5/31 build. used it for a day, then noticed today i had waiting gmail on my laptop but no notifications on my phone.
opened gmail app, back to home, black screen.
same with maps.
then i was like OHHH gapps. so i flashed a backup of gapps i had, i think the same version thats still linked at the first post of this thread.
now everythings working fine.
and now i hear theres a 6/1 update to the rom? should i try it?? this ones working fine.
in a few days im going to be installing this rom on a phone for a family member will it be stable enough or are they moving to a rapid, more buggy, update cycle?
6/1 fixes a few cam bugs and mms.I followed the instructions to download the roms from Rom Manager, installed the 5/31 build. used it for a day, then noticed today i had waiting gmail on my laptop but no notifications on my phone.
same with maps.
I would suggest holding off on ROM Manager till next week, when hopefully we will have offical Optimus V support. I have had two corrupt downloads via ROM Manager, one wasn't even recognized by 7-zip as a zip file.
I downloaded the 6/1 build from a link posted in the thread over at xda, grabbed the framework and systemui apks, cooked my theme at UOT, rebooted into recovery, backup, wiped cache/dalvik-cache, flashed ROM then gapps then UOT theme, rebooted, no issues.
Only bug I've found so far it camera won't autofocus, which keeps barcode scanners from functioning properly (though QR codes seem to work).
Thanks for the linkhttp://www.mediafire.com/?v44km5t066ebs8w found this on the Optimus S forum
Sent from my VM670 using Tapatalk
Stupid question I know. I love the power controls in notification but the only one I can never choose as an option is the 2g/3g toggle. Do I have to install something else for this to be enabled?
Thanks for the link
From what I understand, virgin doesn't have 2g. Its no g 1x 3g
