What is the recommended backup, wipe, install, restore method for this ROM?
1xRTT is generally considered to be 2G or 2.5G. It and EvDO (3G) are both part of the CDMA2000 standard.From what I understand, virgin doesn't have 2g. Its no g 1x 3g
Toggle2g is no longer on market just the plugin. Anybody have a link to an installer for it?
I can't get this ROM to function at all.
I haven't been able to get ANY versions of 2.3.4 to work.
It flashes, boots into the android "Touch here to begin" - which I do, and it reboots to the same screen.
I touch the android the 2nd time, it won't reboot, it's just frozen.
These same symptoms happen with any version of 2.3.4 CM7 I've tried.
Any tips on resolving this? Anyone else see this?
sorry for double posting, but i figured i would install 6/1 through recovery instead of going through rom manager. is the market app included in this build through rom manager? i am flashing the gapps file from recovery after the 6/1 install. After doing all this, my SD card's memory is slowly being used up in front of my own eyes, 360mb, 289mb, 144mb etc...hmmm can't explain it
Is Bluetooth or headset support fixed yet? It's the one thing keeping me from staying with CM7, since I make phone calls while driving often and it's mandatory to use handsfree communications here. Even if speakerphone is fixed, my phone speaker is too quiet in my loud car to be useful, so it had to be wired mic/headset or Bluetooth.
Sent from my VM670 using Tapatalk
