Wifi tethering is working for me using barnacle wifi tethering.
Havent used that app with this ROM yet.. ill have to test it later..
WiFi in general works fine on my end and so does GPS!..
NEW ISSUE (could be my doing):
When tapping the power button the screen will not go to lock mode and turn off like it used too..
Worked fine about 5hrs ago..
Holding the button will still allow me to shutphone down as well as Reboot and what not.. Plus the button will turn the screen on however I just can not for the life of me get the screen to turn off with the power button..
Could be some setting however I have looked over all of the settings and see nothing towards the power button other then to end calls..
I have even adb shelled to the phone and grabed the THUNDER_KEYPAD.kl and all the settings look normal..
Any suggestions?
UPDATE:
cancel my issue..
I forgot I changed the "END BUTTON BEHAVIOR" within "SPARE PARTS" to "DO NOTHING"..
Issue is fixed..
Man I feel like a dumb azz~
