mrg666
Unfortunately android.git.kernel.org/repo is still down.
With the latest changes, syncing works without any complication/modification. I did not have any problem with syncing with the following sequence.
- create another android directory
- go into that directory and issue the following command
repo init -u http://github.com/inferiorhumanorgans/android/ -b gingerbread
- then, do
repo sync
Building is the same, i.e.
source build/envsetup.sh
lunch 4 (VM670 is now item 4 in the lunch menu)
make bacon
I have attached the latest repo here. I hope these work for you as well.
