Yeah, now that I have the center clock animating properly, I can add the date back without overlay issues.Hey Jerry, Is the Date view not working with the latest status bar changes? I see that the Statusbar Date view is commented out in the notification drop down. Will that be worked back in?
I added this commit last night to fix the date overlay issues with the notification icons. Please note the comment at the bottom of the commit, if you are not using my transparency modifications, you only need to add the last few lines of the commit. What it does is adds an animation to the notification icons when the date's animation is called, both out an in.
https://github.com/JerryScript/android_frameworks_base/commit/c723fa98e4fed052cf52c43bda5ecabed50b8aeb#comments
You would either need to repo sync with my repository, git@github.com:JerryScript/android.git -b gingerbread, or cherry-pick the commits and then merge them in using git. If you haven't set up your local repository with branches and remotes, it would be best for you to sync from my repository.
While I'm getting the hang of git, the only cherry-picking I do is via gerrit with c&p. You'll have to read the git documentation to understand how to cherry-pick what you want. Of course, you can always apply the changes manually, something I've resorted to in the past, but what a pita!
@JerryScript: I think I've found all the bloat in the ROM that I built.
Half seems to be in the extra languages. I found a commit in your git tree that switches to languages_small.mk.
The other half is in files that you removed: half a dozen apk's, many ringtones, etc. Sorry if this is a noob question, but how do you remove those? Do you disable them via the build system, or do you do an unzip/delete/rezip?
I disable them in the build, for audio files, you have to delete from 5 different AudioPackage mk files. They are located in frameworks/base/data/sounds
private static final int BIT_HEADSET = (1 << 0);
private static final int BIT_HEADSET_NO_MIC = (1 << 1);
//change to
private static final int BIT_HEADSET = (1 << 1);
private static final int BIT_HEADSET_NO_MIC = (1 << 0);
Here's the webkit accelerator. Testing it right now. Here's what it is supposed to do. Android Webkit browser accelerated - YouTube
In the BoardConfig.mk add:
WEBCORE_ACCELERATED_SCROLLING := true
And in device_thunderc.mk add
vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/lib/libwebkitaccel.so:system/lib/libwebkitaccel.so \
vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/lib/libwebkitaccel.sobj/lib/libwebkitaccel.so
Then place the libwebkitaccel.so in your vendor/lge/thunderc/proprietary/VM670/system/lib folder.
Grab the file from [MOD] HW Acceleration for CM7/AOSP Browser [Tested working] - xda-developers.
