I read the OP and It makes sense to me as i am a linux user, but, once you actually create the rom, how would modify it and such? and how would you port a rom to the OV? like ICS, MIUI, or sense or something? links would be appreciated sorry If someone already posted this, I must of missed it :0
Well to modify the rom, you change the code that you compile and what files are or are not included, then you compile and you have your modified rom. As for porting... that's entirely different since source code is normally not included. Both gannon and theunknownartist have guides on porting.
errr... extremely frustrated... about to break laptop over my knee and give up... no matter what i try: directions from op, other scripts, various other googlefu trys... cannot seem to make any progress... is there ANY up to date, step by step guide to build for the ov?... please forgive me... ill keep trying... thanks to everyone who has helped!...
[SIZE="3"]sudo apt-get install git-core gnupg flex bison gperf build-essential \
zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev \
libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev:i386 \
g++-multilib mingw32 openjdk-6-jdk tofrodos python-markdown \
libxml2-utils xsltproc zlib1g-dev:i386[/SIZE]
im about to attempt to lunch... do i select vm670-eng or vm670-userdebug?... Anyone...
Well now I'm back to my old issue. I can get a working build with apparently no radio functions Click to view quoted image
I've made no changes just sync with Jerrys github and make bacon so it should work...
[SIZE="2"]sudo apt-get install git-core gnupg flex bison gperf build-essential \
make: *** [out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/noproguard.classes-with-local.dex] Killed
clodfelterac@myUBUNTUlaptop:~/mylab$
i think i got hung up... this is what it finished with... i didnt see a .zip in /thunderc_VM670... do i need to compress these files and make the .zip myself?... or try to build again with -userdebug?... i chose -eng this time... thanks for any help... glad ive made it this far!...
Just wanted to thank everyone on this thread that has given advice. I've been following for a coulpe of weeks. (I'm a slow learner)lol And didn't think I would ever figure it out . But tonight I built my first rom following these instructions. Like "Earthfire78" said Linux mint requires some packages that ubuntu already have I guess. Anyway, just wanted to say thanks. Hope to keep following and learning!
AH SUCCESS @ LAST!!!...
finally figured out what was going on...
syncing now...
big THANKS to blarf, jerry, bob, tdm, tvall, sellers, anthony, pbaily, cole, wraith, and anyone im forgetting for the help they offered when i needed it...
sooooo relieved... lol
THANK YOU ALL!
You have to get sun java6 from a different source, I can't remember if I used lucid or multiverse or both:
Code:sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner" // or sudo add-apt-repository "deb http://us.archive.ubuntu.com/ubuntu/ hardy multiverse"
Ok now I have a new problem. Forgive me if this has already been covered but I've searched for two days to no avail! I recently upgraded to mint 13(Maya) l have Java 1.7 so I get this error, (need Java 1.6). I've tried every way to get 1.6 with no luck. Can anyone direct me in the right direction? Thanks in advance. Sorry noob here.lol
Edit: I'm pretty sure I don't have the correct repository in my source. List
