EarthnFire78
YAY!!! ME :)
Just realized that my video camera recording is broken, whats the fix? Point to the file I need to fix.
Check the OMX libs and system/etc/media_profiles.xml.
Alright, I need some help. Im stumped, and I cant get this. heres the error
build/core/node_fns.mk:187: *** unterminated call to function `call': missing `)'. Stop.
I get this after I run lunch. and this is all I get.
node_fns.mk in build/core/ is missing a ) mark, aka a parenthesis is open on line 187 and not closed
I have a question guys: every time I build fails with an error, do I have to run make clean and start fresh?
tapatalked? from cowsquadGnex?
No just fix the error and run make again.
But you do want to make clean when you change build settings, eg. in your BoardConfig.mk or device.mk.
Damn it . I ran make clean every time I got an error. :banghead:
Can you post what the error is your are getting?
I am getting this
Make: *** no rule to make target 'otapackage' .stop
Use make bacon if you are building cyanogenmod
Sent from my One V using Android Central Forums
I am building aosp . How do I go with that?
. build/envsetup.sh
lunch "whatever the package you wish to build (for VM670 "8")
make -j(number of CPU Treads) bacon
I am getting this
