Building your own ROM
cowsquad
Active member
Mar 27, 2012
35
Did you pick your lunch menu first?
Code:
. build/envsetup.sh
lunch "whatever the package you wish to build (for VM670 "8")
make -j(number of CPU Treads) bacon
The thing is that toro is not on the list on the menu. So I lunch full_toro-userdebug and the make -j4 otapackage and I still getting the same error. I am gonna try the patch below
tapatalked? from cowsquadGnex?
koeylondon
226
MOAR NUB Q's!
OK, so installing the environment as the 3rd post: the package lib32readline5-dev doesn't seem to exist. I find lib32readline6-dev, but other searches return nothing. Helpz?
Feb 19, 2011
1,971
284
did you
Code:
. build/envsetup.sh
/edit/
sorry, my phone browser went all psychotic and was replying to an old post.
duh.... been a poor week for brain function.
cowsquad
Active member
Mar 27, 2012
35
javadoc: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
make: *** [out/target/common/docs/doc-comment-check-timestamp] Error 45
make: *** Waiting for unfinished jobs....
make: *** [out/target/common/docs/api-stubs-timestamp] Error 45
i did run make -j4 and the compiler took like 3 hours to finish. Now, i am getting those errors above
I did run make
sellers86
1,837
617
I did run make
You need to post more than this.
Sent from my One V using Android Central Forums
cowsquad
Active member
Mar 27, 2012
35
Wee need to know where its erroring at. Just post more output than what you did.
this is the entire error
Docs droiddoc: out/target/common/docs/doc-comment-check
Docs droiddoc: out/target/common/docs/api-stubs
target SharedLib: libutils (out/target/product/generic/obj/SHARED_LIBRARIES/libutils_intermediates/LINKED/libutils.so)
target SharedLib: libhardware_legacy (out/target/product/generic/obj/SHARED_LIBRARIES/libhardware_legacy_intermediates/LINKED/libhardware_legacy.so)
target Symbolic: libdvm (out/target/product/generic/symbols/system/lib/libdvm.so)
Install: out/host/linux-x86/lib/libdvm.so
Install: out/host/linux-x86/lib/libSR_Core.so
sellers86
1,837
617
I am building Aosp.
Really? Anyways, now that I look at it closer, hardware/libhardware_legacy doesn't seem like its throwing the errors. But, I'm done helping, seeing as you like to argue about everything and I don't feel like dealing with it right now.
cowsquad
Active member
Mar 27, 2012
35
Huh? Arguing? When? Okay, don't worry man. I'll fix it on my own. Don't worry
drewwalton19216801
2,476
2,803
Are you on you period lol jk . Cool, :)
Neither of these posts are helpful at all, let's try and keep things civil. You've both been reported.
cowsquad
Active member
Mar 27, 2012
35
OK. I was going to take a look. Libjli.so is having problems
So libjli is part of java SDK 6 and it is located in its respective folder. I already created a alternative for javadoc as well, but that doesn't help. When I run make -j4 otapackage , I don't get that error. Weird
