There seems to be some confusion on the subject of overclocking. Here are a few points to remember, please add to this as it is not complete:
---WARNING- Overclocking can adversely affect your phone, and it may shorten it's lifespan, though most likely you will get a different phone way before that happens.
---Do not select "Set On Boot" until you are sure you are at a stable speed!!!
---Each phone will behave differently, there is no magic number that you should be able to overclock to, our CPUs are rated at 600, but in reality they are built for a higher number. Once built, they are tested for stability, and as long as they are stable at 600, they are shipped. They may be perfectly fine at 806-864, though most people find 768-787 to be the sweetspot for the OV.
---Test with all apps to be sure of stability, just because you are stable most of the time, once you try to use certain apps, you may find your phone crashing, apps such as the camera, gallery, youtube, netflix, just about anything that involves streaming media or graphics acceleration will show instability before most other apps will.
---Different ROMs use different kernels, and the overclocking and schedulers will be different with each, so just because you ran stable on one ROM at a certain speed does not mean you will on all of them.
You best bet for finding your phone's overclocking sweet spot is to start at 806, then try every single app you can think of that has high demands, if your phone crashes, drop it down a notch and test again. Once you find what appears to be a stable overclock value, drop it down another notch, and you most likely will never have another overclock related crash.
