04-20-2012 06:29 PM
52 123
tools
  1. ShadyBusiness's Avatar
    In recovery, this is navigating ClockworkMod to clear cache, dalvik-cache, perform a wipe, then a restore... Without looking...
    Sent from my LG Optimus-V using Tapatalk
    I'd rather diffuse a bomb.
    09-22-2011 04:32 PM
  2. totombane's Avatar
    nothing happens at all it just keeps the backlite on
    09-22-2011 05:20 PM
  3. ShortRound51's Avatar
    Hmm... Wish I could put my hands on it... Bet I could fix it one way or another...
    Give me a bit I will come up with something...
    09-22-2011 06:18 PM
  4. ShortRound51's Avatar
    See if you can get an adb connection.
    Connect your phone to your PC... Boot phone into recovery...
    Open a command prompt...
    Navigate to c:\program files\Android\Android-sdk\platform-tools
    Type adb shell
    You should get a # prompt
    Let me know if you get this far...
    09-23-2011 06:44 AM
  5. totombane's Avatar
    should i use my computers cmd?
    and how do i navigate to c:\program files\Android\Android-sdk\platform-tools?
    sorry but ive never done this!
    is there anyway to compleatly wipe the phone clean and fresh..... id dont mind losing data as much as buying a new phone.
    09-23-2011 07:23 AM
  6. ShortRound51's Avatar
    If you can download the IHO Recovery: http://inferiorhumanorgans.com/andro...-4.0.1.4.3.img
    Go back to the commands prompt and type: mount /sdcard
    Then open the SD card in windows and place the recovery file on the root of the SD card
    Back to the command prompt type the following:
    mount /system
    /system/bin/flash_image recovery iho-vm670-recovery-4.0.1.4.3.img
    May take a few moments
    Then type: reboot recovery
    09-23-2011 07:24 AM
  7. ShortRound51's Avatar
    Yes the computers cmd
    when your get to the cmd prompt type: cd c:\program files\Android\Android-sdk\platform-tools
    Unfortunately not, would be nice to have a reset button...
    totombane likes this.
    09-23-2011 07:27 AM
  8. totombane's Avatar
    it says
    system cannot find path specified. i copy and pasted cd c:\program files\Android\Android-sdk\platform-tools to cmd.
    im going to be gone over the weekend so i wont be able to reply to you posts but keep throwing ideas out.
    shortround would it be possable to sent you my phone to fix it? i would pay you.
    thanks for all the help you guys im grateful!
    09-23-2011 08:06 AM
  9. ShortRound51's Avatar
    it says
    I an sorry, but I couldn't do that. I refuse to give out my address to have it shipped.
    09-23-2011 08:39 AM
  10. totombane's Avatar
    would lg factory fix it if i sent it to them? if not where could i take it to be repaired
    09-23-2011 08:49 AM
  11. Eollie's Avatar
    search for androidscreencast. it will allow you to see the phone screen on your pc.
    09-23-2011 09:06 AM
  12. DroidXcon's Avatar
    Toto if you want I can screen share your computer and get you adb connected if its possible. I say possible because it needs to be in debugging mode for it to work. But its worth a shot
    Sent from my SCH-I510 using Tapatalk
    09-23-2011 09:25 AM
  13. ShortRound51's Avatar
    Your voided the warranty by rooting the phone...
    09-23-2011 09:26 AM
  14. ShortRound51's Avatar
    Was tried wouldn't connect...
    09-23-2011 09:27 AM
  15. ShortRound51's Avatar
    Doesn't matter in recovery... The restore was botched so he cannot boot normally...
    09-23-2011 09:28 AM
  16. DroidXcon's Avatar
    On the other hand if they try to turn it on and can not get past the logo screen they won't waste time trying to diagnose the problem they will just reflash the original software and be done with it
    09-23-2011 09:31 AM
  17. totombane's Avatar
    we have already tried this
    09-23-2011 09:32 AM
  18. totombane's Avatar
    i will be away over weekend but when i get back i might be able to try this
    and shortround i know i voided my warrenty but could i still pay them to fix it?
    09-23-2011 09:35 AM
  19. DroidXcon's Avatar
    Well I can see if I can get adb to work but it would probably need to be in recovery to shell so we can push. if it cant connect he can always just go to his dealer and say it frozr during factory reset they may just replace it no questions
    09-23-2011 09:39 AM
  20. DroidXcon's Avatar
    Yeah message me when you get back and ill let see what I can do. Have a good weekend ....and yes you can always pay them. But I would just omit what you did and try your luck
    09-23-2011 09:41 AM
  21. ShortRound51's Avatar
    True, but now you are condoning fraud... While they would certainly replace it, I myself will not recommend this course of action...
    09-23-2011 09:44 AM
  22. totombane's Avatar
    yeah im not going to lie about it since it was my fault
    09-23-2011 09:46 AM
  23. Eollie's Avatar
    No.
    This.
    Is.
    Wrong.
    To.
    Suggest.
    Seriously as a senior advisor you should knoe better then to advocate returning a phone the USER broke.
    Now back to android screencast. Yes you tried it but did you remount the phone? It wont work on my pc if I dont do adb remount. It will fail to load and error everytime.
    I dont remember if anybody asked this or not. How did you restore the backup? Im getting a strong sense you used the lg reset from within the phone menu. If so that opens another can of worms.
    09-23-2011 09:46 AM
  24. DroidXcon's Avatar
    Then don't omit. They may still replace it despite the knowledge of it being modifed. At worst pay for the repair ,if we can't get it fixed.But either way let me know when you get back and ill try to get you connected.
    09-23-2011 10:09 AM
  25. fenrix's Avatar
    Fastboot and ADB Command Line tools for Android. - xda-developers
    See ATTACHED FILES.
    much easier than d/ling the whole SDK,& searching folders
    09-23-2011 10:19 AM
52 123
