Optimus will not turn on
ShortRound51
88
13
ok i installed java 7 jdk and then installed android sdk then saved the android screencast and put my phone into recovery mode (even though it only has a back-lit screen still) then plugged my phone into my pc. i checked my printers and devices and my optimus is reconized by the computer. then open screencast and it says getting device list for about 10 second the a message pops up and says unable to lauch application.
i've about had it with trying to fix this phone.
You can always try doing it the blind way. What you need to try is to load your backup... Unfortunately with the screen not functioning it is difficult.
Let me do some research. And if anyone else would like to chime in with suggestions, wouldn't bother me in the slightest.
Sent from my LG Optimus-V using Tapatalk
ShadyBusiness
Active member
Sep 18, 2011
37
5
Boot into recovery and follow shortround's steps very carefully whiles in recovery. Your screen is supposed to be black... Well its not supposed to be black, but you know what I mean.
ShortRound51
88
13
If you wish to try it blind... Here is the key sequence:
DO THIS AT YOUR OWN RISK!!!
If not done exactly, it could mess even more up!
D - Volume Down Button
U - Volume Up Button
C - Camera Button
B - Back Button
DDC UUUUC
Pause about 5 seconds...
UUC DC UUUUC
Pause about 10 seconds...
B DDDC UUUUC
Pause about 30 seconds...
UUUUC DC C UUUUC
Pause about 90 seconds...
C
Press each key firmly. There is no auto repeat, so don't worry about that. After you do this it should reboot, and just let it sit... the phone should boot but may take a long first boot.
Reactions: totombane
ShortRound51
88
13
Hmm... Wish I could put my hands on it... Bet I could fix it one way or another...
Give me a bit I will come up with something...
ShortRound51
88
13
See if you can get an adb connection.
Connect your phone to your PC... Boot phone into recovery...
Open a command prompt...
Navigate to c:\program files\Android\Android-sdk\platform-tools
Type adb shell
You should get a # prompt
Let me know if you get this far...
totombane
18
should i use my computers cmd?
and how do i navigate to c:\program files\Android\Android-sdk\platform-tools?
sorry but ive never done this!
is there anyway to compleatly wipe the phone clean and fresh..... id dont mind losing data as much as buying a new phone.
ShortRound51
88
13
If you can download the IHO Recovery: http://inferiorhumanorgans.com/android/iho-vm670-recovery-4.0.1.4.3.img
Go back to the commands prompt and type: mount /sdcard
Then open the SD card in windows and place the recovery file on the root of the SD card
Back to the command prompt type the following:
mount /system
/system/bin/flash_image recovery iho-vm670-recovery-4.0.1.4.3.img
May take a few moments
Then type: reboot recovery
ShortRound51
88
13
Yes the computers cmd
when your get to the cmd prompt type: cd c:\program files\Android\Android-sdk\platform-tools
Unfortunately not, would be nice to have a reset button...
totombane
18
it says
system cannot find path specified. i copy and pasted cd c:\program files\Android\Android-sdk\platform-tools to cmd.
im going to be gone over the weekend so i wont be able to reply to you posts but keep throwing ideas out.
shortround would it be possable to sent you my phone to fix it? i would pay you.
thanks for all the help you guys im grateful!
ShortRound51
88
13
it says
I an sorry, but I couldn't do that. I refuse to give out my address to have it shipped.
DroidXcon
11,102
3,392
Toto if you want I can screen share your computer and get you adb connected if its possible. I say possible because it needs to be in debugging mode for it to work. But its worth a shot
Sent from my SCH-I510 using Tapatalk
ShortRound51
88
13
Doesn't matter in recovery... The restore was botched so he cannot boot normally...
