ShortRound51
ok i installed java 7 jdk and then installed android sdk then saved the android screencast and put my phone into recovery mode (even though it only has a back-lit screen still) then plugged my phone into my pc. i checked my printers and devices and my optimus is reconized by the computer. then open screencast and it says getting device list for about 10 second the a message pops up and says unable to lauch application.
i've about had it with trying to fix this phone.
You can always try doing it the blind way. What you need to try is to load your backup... Unfortunately with the screen not functioning it is difficult.
Let me do some research. And if anyone else would like to chime in with suggestions, wouldn't bother me in the slightest.
Sent from my LG Optimus-V using Tapatalk
