04-20-2012 07:29 PM
52 123
tools
  1. totombane's Avatar
    Ok So here is the story. I rooted my phone several days ago using gingerbreak. everything worked fine until i decided to leave well enough alone. I backed up my files with ROM Manger and it rebooted my phone. Great! But then i decided to restore back to my original files just to make sure everything about the back up was ok. During the restore the Optimus v compleatly froze so i did the old pull battery trick hoping i could just reboot the phone and try it again. i replaced the battery and powered it up. the lg logo came up followed by the virgin mobil animation but after the animation was over the virgin mobile logo faze and did not transition to the android logo. I've searched google for hours trying to figure this problem out. I tried putting the phone into recovery mode but all that happens is the lg symbol flashing on the screen for about an second the freezes on a black back lit screen. I'm out of things to try and really dont want to pay for a new phone. like i said i have searched and searched for answers but all i got was:
    A. Answer does not work
    B. I cant figure out all the tech jargon
    C. all the other answers require me to get into recovery mode which i cant.
    So to some this post up:
    1. I cant get past the Virgin Mobile animation
    2. when i hold Home+down volume then power it just flashes the lg logo and freezes on back lit screen
    3. I NEED HELP
    09-21-2011 04:27 PM
  2. jdcnosse's Avatar
    ROM Manager isn't very supported on our phone, and should only be used to flash ClockworkMod recovery over the stock one (right after you root). That's pretty much it's only use for us Optimus V owners.
    idk what you did, and but hopefully someone else can come along and help you out or at least tell you if you've completely borked or phone or not.
    09-21-2011 04:45 PM
  3. totombane's Avatar
    well thx unfortunatly i didnt find that at till right now
    09-21-2011 04:50 PM
  4. ShortRound51's Avatar
    Well let's try something different, can you get into emergency mode? (hold menu key, down volume, power)
    You will need adb (from the Android sdk) on your computer... You probably need to reflash ClockworkMod so you will need to download and put it on your SD card... You can get the IHO Recovery from their site (it works better than the original ClockworkMod anyway)
    Sent from my LG Optimus-V using Tapatalk
    09-21-2011 05:06 PM
  5. totombane's Avatar
    i cant get it into emergency mode.
    can you walk me through how to put clockwork on my sd card and talk me through the process in detail please?
    09-21-2011 05:17 PM
  6. jdcnosse's Avatar
    I thought Menu, Down volume, and power booted you into Recovery mode?
    According to this:
    http://forums.androidcentral.com/opt...on-combos.html
    Boot into Emergency Mode:
    Power off.
    Plug in the USB cable and wait for the charging screen to come on.
    Hold the Return Button, Volume Down Button, and the Power Button at the same time.
    Release when you first see the LG logo.
    Yeah unfortunately. :/ I believe there's a fix around, but don't quote me on that lol. At least you learned something today!
    09-21-2011 05:24 PM
  7. ShortRound51's Avatar
    Sorry, emergency mode is back button, volume down, and power...
    I am not sure where to get the actual ClockworkMod Recovery, but you can get the IHO version from their github site. As far as getting it on the card, let's take one step at a time. And see if we can fix it first.
    Goto the LG update tool (not sure where to find it, just google it)
    Connect the phone to your PC and and boot into emergency mode... Go to devices on your computer and you will see 3 LG hardwares, disable the modem one, and run the tool...then reboot.
    09-21-2011 05:42 PM
  8. totombane's Avatar
    ok i've got it into emergency mode now what?
    Edit- sorry did not see your reply shortround-edit
    09-21-2011 05:48 PM
  9. totombane's Avatar
    im running windows 7 64bit os
    there is no disable option when i right click modem 1
    09-21-2011 06:00 PM
  10. ShadyBusiness's Avatar
    You might have a new OpV with the new screen
    I know you're already beeing helped and stuff but my problem was somewhat similar to yours.
    Anyways I was able to fix it by installing the Android SDK Android SDK | Android Developers and JDK Java SE Downloads Android Screencast Android Screencast
    (No install just save the file) and the LG Mobile Update Tool http://www.lg.com/us/mobile-phones/R...ML_Ver_1.0.msi
    One all these things are installed/downloaded boot into recovery(Volup+Home+Power) or (voldown+home+power) both boot into recovery for me, but yeah. then plug in your phone via usb and as long as the computer recognizes it(takes a while sometimes) open android screencast and if it worked correctly you should be able to see your phone's screen and you can run recovery from there(Control with your phone) and Install a compatible recovery and a new rom and stuff like that.
    Not sure if this will solve your problem but its worth a shot.
    09-21-2011 06:03 PM
  11. totombane's Avatar
    thx i will try this if shortround is unable to help fix this
    09-21-2011 06:09 PM
  12. totombane's Avatar
    ok shortround i was able to disable the modem lg one and run tools mobile lg
    i downloaded the correct drivers(optimus v is model # 670 right?) and the clicked start updating where i got the message software update not supported for this model! HELP
    ps. this happens around the 36% mark on the analyzing area of the lg tools update.
    09-21-2011 06:17 PM
  13. ShortRound51's Avatar
    I suggest you try ShadyBusiness's approach. I forgot completely about the new screens. And after reviewing your issue I agree that this could very well fix it. Everything could be working but the screen just isnt working. Give this a try. I will be monitoring this thread.
    09-21-2011 06:19 PM
  14. ShortRound51's Avatar
    i downloaded the correct drivers(optimus v is model # 670 right?) and the clicked start updating where i got the message drivers not correct for model
    well, we need the drivers then. but lets try ShadyBusiness's approach first.
    09-21-2011 06:19 PM
  15. ShortRound51's Avatar
    Read this thread from the Stickies section, it may shine some more light on the issue.
    http://forums.androidcentral.com/opt...stom-roms.html
    09-21-2011 06:23 PM
  16. ShadyBusiness's Avatar
    Theres no need to click start updating. Just install the USB drivers through the button where it says Install the USB drivers (VM670) and the drivers are installed.
    09-21-2011 06:27 PM
  17. totombane's Avatar
    i did read it and could not figure in out can you explain to me in detail how to do shadies approch
    09-21-2011 06:27 PM
  18. ShadyBusiness's Avatar
    I already told you how to do it lol. Just read more carefully.
    09-21-2011 06:31 PM
  19. ShortRound51's Avatar
    Like shady business stated. Just install these items and do as he says...
    You will need to install the Java SE one first then the Android SDK...
    Other than that it is pretty straight forward. Give it a try, and let us know if/where you get stuck...
    09-21-2011 06:59 PM
  20. totombane's Avatar
    ok i installed java 7 jdk and then installed android sdk then saved the android screencast and put my phone into recovery mode (even though it only has a back-lit screen still) then plugged my phone into my pc. i checked my printers and devices and my optimus is reconized by the computer. then open screencast and it says getting device list for about 10 second the a message pops up and says unable to lauch application.
    i've about had it with trying to fix this phone.
    09-22-2011 10:31 AM
  21. ShortRound51's Avatar
    You can always try doing it the blind way. What you need to try is to load your backup... Unfortunately with the screen not functioning it is difficult.
    Let me do some research. And if anyone else would like to chime in with suggestions, wouldn't bother me in the slightest.
    09-22-2011 02:58 PM
  22. ShadyBusiness's Avatar
    Boot into recovery and follow shortround's steps very carefully whiles in recovery. Your screen is supposed to be black... Well its not supposed to be black, but you know what I mean.
    09-22-2011 02:59 PM
  23. ShortRound51's Avatar
    If you wish to try it blind... Here is the key sequence:
    DO THIS AT YOUR OWN RISK!!!
    If not done exactly, it could mess even more up!
    D - Volume Down Button
    U - Volume Up Button
    C - Camera Button
    B - Back Button
    DDC UUUUC
    Pause about 5 seconds...
    UUC DC UUUUC
    Pause about 10 seconds...
    B DDDC UUUUC
    Pause about 30 seconds...
    UUUUC DC C UUUUC
    Pause about 90 seconds...
    C
    Press each key firmly. There is no auto repeat, so don't worry about that. After you do this it should reboot, and just let it sit... the phone should boot but may take a long first boot.
    totombane likes this.
    09-22-2011 03:24 PM
  24. totombane's Avatar
    Do i do this in recovery mode or just when its powered off?
    09-22-2011 04:50 PM
  25. ShortRound51's Avatar
    In recovery, this is navigating ClockworkMod to clear cache, dalvik-cache, perform a wipe, then a restore... Without looking...
    09-22-2011 05:18 PM
52 123
