I was using the sticky to get my custom recovery so I can install a rom.
It's rooted and all that, but the recovery flash is not working. I cannot get adb to work at all, so I used the terminal emulator.
I typed this in.
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
flash_image recovery /sdcard/recovery-thunderc-v-1.2.0-GNM.img
reboot recovery
This is what I got back.
# mtdblock5: not found
# cannot create /system/bin: is a directory
# flash_image: not found
# Unable to chmod /flash_image: No such file or directory
# Usage: mount [-r] [-w] [-o options] [-t type] device directory
Anyone have an idea on what's going on?
Thanks
I typed this in.
su
reboot recovery
Thanks
