first of all, the themes have to be made for an MDPI device, the theme maker had to have put all the correct icons and say it was compatible with MDPI phones. otherwise you might not see everything, as the optimus V is mdpi
second, you have to reboot after you apply the theme so the caches can rebuild. sure you might see most of the theme after applying it but icons and stuff usually dont show up till after a reboot
