03-01-2012 08:14 AM
339 ... 1011121314
tools
  1. rukin5197's Avatar
    Has anyone tried looking in the eri.xml for changing the "Roaming" on the lockscreen and pull down?
    At least as a temporary fix until they look at ours as Virgin Mobile
    02-17-2012 08:41 PM
  2. tdm's Avatar
    After 7 hours of compiling, I get this:
    Code:
    Install system fs image: out/target/product/thunderc/system.img
    out/target/product/thunderc/system.img+out/target/product/thunderc/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p total size is 183328621
    error: out/target/product/thunderc/system.img+out/target/product/thunderc/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p too large (183328621 > [177881088 - 1892352])
    make: *** [out/target/product/thunderc/system.img] Error 1
    make: *** Deleting file `out/target/product/thunderc/system.img'
    Yeah it's huge.
    I've found that using languages_small and removing some junk like live wallpapers does the trick.
    02-17-2012 08:43 PM
  3. tdm's Avatar
    Well here is the Trebuchet.apk editted. It is 1.14 MB... 80% smaller than it originally was. Maybe I could scale down other apps too
    Awesomeness, thanks! Mind sharing what you did?
    02-17-2012 08:44 PM
  4. Jk16w's Avatar
    Well what ever he did he took a 9.56mb made it into a 1.14mb file, and 528kb install made into a 0.98kb install
    02-17-2012 08:47 PM
  5. anthonycr's Avatar
    Well I extracted it from your ROM zip, then opened it in 7zip to look at the files... needless to say, because it was built for hdpi devices, the wallpapers were way too big (a couple were almost 1 MB!!), so I deleted the xhdpi ones and resized the ones that our phones used, and voila! its smaller.
    tdm, bdfull3r, Badboytoast and 1 others like this.
    02-17-2012 08:48 PM
  6. tdm's Avatar
    Cool. I've been meaning to get rid of the xhdpi images. This gives me a great reason!
    02-17-2012 08:55 PM
  7. tdm's Avatar
    So i'm getting this at the end of the build process. Is this common or just me? I get the thunderc-ota-eng.thekraven.zip file but not the user one.
    Code:
    building image from target_files BOOT...
      running:  mkbootfs /tmp/targetfiles-qUop1h/BOOT/RAMDISK
      running:  minigzip
      running:  mkbootimg --kernel /tmp/targetfiles-qUop1h/BOOT/kernel --cmdline mem=471M console=ttyMSM2,115200n8 androidboot.hardware=thunderc --base 0x12200000 --pagesize 2048 --ramdisk /tmp/tmpy4fksA --output /tmp/tmpnRLsCA
      running:  openssl pkcs8 -in build/target/product/security/testkey.pk8 -inform DER -nocrypt
      running:  java -Xmx2048m -jar out/host/linux-x86/framework/signapk.jar -w build/target/product/security/testkey.x509.pem build/target/product/security/testkey.pk8 /tmp/tmpEcp4lq out/target/product/thunderc/thunderc-ota-eng.thekraven.zip
    done.
    /home/thekraven/android/system/out/target/product/thunderc/thunderc-ota-user.thekraven.zip doesn't exist!
    make: *** [bacon] Error 1
    I think the CM scripts don't handle user release builds well. Try this diff:
    Code:
    diff --git a/prebuilt/common/bootanimation.zip b/prebuilt/common/bootanimation.zip
    index 528e840..6ca885e 100644
    Binary files a/prebuilt/common/bootanimation.zip and b/prebuilt/common/bootanimation.zip differ
    diff --git a/tools/opticharger b/tools/opticharger
    index c8c86f5..8e63bf9 100755
    --- a/tools/opticharger
    +++ b/tools/opticharger
    @@ -32,6 +32,8 @@ if [ "$APKCERTS" = "" ];
     then
         if [ "$TARGET_BUILD_VARIANT" = "userdebug" ]; then
            TARGET_BUILD_VARIANT="eng"
    +    elif [ "$TARGET_BUILD_VARIANT" = "user" ]; then
    +       TARGET_BUILD_VARIANT="eng"
         fi
         APKCERTS=$OUT/obj/PACKAGING/target_files_intermediates/$TARGET_PRODUCT-target_files-$TARGET_BUI
    diff --git a/tools/squisher b/tools/squisher
    index cbd154f..edc5828 100755
    --- a/tools/squisher
    +++ b/tools/squisher
    @@ -1,9 +1,11 @@
    -#!/bin/sh
    +#!/bin/sh -x
     # Squish a CM otapackage for distribution
     # cyanogen
    +set
     OUT_TARGET_HOST=`uname -a | grep Darwin`
     if [ -z "$OUT_TARGET_HOST" ]
     then
    @@ -27,6 +29,8 @@ if [ "$TARGET_BUILD_TYPE" = "debug" ]; then
         OTAPACKAGE=$OUT/${TARGET_PRODUCT}_debug-ota-$TARGET_BUILD_VARIANT.$USER.zip
     elif [ "$TARGET_BUILD_VARIANT" = "userdebug" ]; then
         OTAPACKAGE=$OUT/$TARGET_PRODUCT-ota-eng.$USER.zip
    +elif [ "$TARGET_BUILD_VARIANT" = "user" ]; then
    +    OTAPACKAGE=$OUT/$TARGET_PRODUCT-ota-eng.$USER.zip
     else
         OTAPACKAGE=$OUT/$TARGET_PRODUCT-ota-$TARGET_BUILD_VARIANT.$USER.zip
     fi
    02-17-2012 08:57 PM
  8. anthonycr's Avatar
    Yeah it should save you a bunch of space in your ROM. Take the Trebuchet.apk to use if it will save you time... idk how it works for you devs.
    I've been trimming out apps and doing a little dieting on the ROM and I already have a fully functional-flashable ROM zip down to 89 MB, so I'm guessing you're not going to have too much trouble
    Awesome job on this ROM so far, its you builders I rely on, because I'm just a geeky kid not some professional
    02-17-2012 09:12 PM
  9. rukin5197's Avatar
    UPDATE:
    H/W Acceleration is a GO! Currently testing a new build of GingerKernel with this ICS build. Angry Birds Rio runs like a champ, as does the Launcher UI. Expect a build release soon
    EDIT: If you would like to preview the new kernel, click here. It's unsigned, so you'll have to turn signature verification off.
    Will this work on our ov? I know we use gingerkernel and all..
    Sent from my Amazon Kindle Fire using Tapatalk
    Masema likes this.
    02-17-2012 10:27 PM
  10. tdm's Avatar
    there's a good chance it will. thanks!
    02-17-2012 11:19 PM
  11. notown's Avatar
    I always move/delete all the original ringtones/notification on the roms i use.. i always use my own to save space.
    Maybe all the ringtones but one can be installed on the SD instead ?
    02-18-2012 03:17 AM
  12. theexile1's Avatar
    im just an average user but i tried the gingerkenral it works its snappier from what ive seen but i have no idea whats behinde the scenes
    02-18-2012 03:43 AM
  13. rukin5197's Avatar
    I second this. MUCH snappier than before. No lag whatsoever
    02-18-2012 09:17 AM
  14. Whyzor's Avatar
    I would suggest keeping development and spare parts apks since they're small and have tools to help troubleshoot problems later. They dont run as services either.
    JerryScript and Anonymo like this.
    02-18-2012 02:22 PM
  15. BobZhome's Avatar
    Don't forget to include the correct apn info in your build: https://github.com/BobZhome/android_...24487d03bcfa9f
    thekraven, notown, Anonymo and 2 others like this.
    02-18-2012 10:12 PM
  16. BobZhome's Avatar
    First pass at trimming ics down wasn't bad.
    My update-cm-9.0.0-RC0--BobZhome-02192012-signed.zip weighted in at 68.7 MB (72,040,448 bytes).
    CM9 with only Titanium Backup, File Manager, and Launcher Pro installed showed 59.9 MB free: Attachment 21721
    After Gapps TB showed 36.3 MB Free:Attachment 21722 , which is better than the first round that I only had 5 kb left
    Bob
    EDIT: forgot to say that my changes are posted on my git.
    02-19-2012 06:14 PM
  17. rukin5197's Avatar
    Bob
    Syncing with your git now
    Did you use my gapps? They're quite small. Lol
    02-19-2012 06:26 PM
  18. tdm's Avatar
    Looks like we've got several successful builds now. I'm assuming at least one other person is interested in releasing a ROM. We can continue in several ways from here: everyone independent, form a team, or do a project like IHO.
    Thoughts?
    I'm personally not much for end user support, I'm pretty happy being a back end type (I'm a server developer IRL). I'd be happy to take up the organizational role in a team or project though.
    02-19-2012 06:29 PM
  19. rukin5197's Avatar
    I don't know if you guys have fixed this yet, but in the updater-script, if you remove retouch_binaries, it will fix the random offset that people seem to not like.. lol
    bdfull3r likes this.
    02-19-2012 06:42 PM
  20. BobZhome's Avatar
    Yes, used your Gapps...Thanks!
    Thoughts?
    I'm also on the quiet side...I plan on doing some kernel work this week.
    If you sync up with CM9...the random offset, when installing rom, has been fixed.
    Bob
    02-19-2012 07:25 PM
  21. JerryScript's Avatar
    If you handle the backend, I'll post any deviation in build instructions in a new Build Your Own ICS thread, and before you know it, we will have several ROMs published.
    I'm of the opinion the more the merrier. It allows different builds focused on different features, sort of how IHO builds are now. No one recipe will satisfy everyone's urges.
    If you guys keep spicing up the sauce, I'll keep modifying the frameworks, while others build pure, and we'll try to keep everyone happy!
    bdfull3r, cmerlyn and clodfelterac like this.
    02-19-2012 08:31 PM
  22. rukin5197's Avatar
    I'll tell you what, if you do it like you did iho, I'll definitely contribute as a developer
    But I support whatever decision you guys make!
    02-19-2012 09:06 PM
  23. tdm's Avatar
    Ok here's what I'm thinking:
    Either we'll use blarf's IHO project with his permission or we'll create a new project depending on his feelings. I get the sense he's okay with it but we'll need to make sure.
    The main ics branch will be for the "vanilla" code, pretty much as the IHO repo stands now. Each developer takes a branch for their own ROM and adds their special sauce on their branch. This way devs can share commits and discoveries. And if a particular change is popular enough, it can be pushed down to the ics branch to be "official". All commits to the ics branch should be reviewed by at least one other developer to try to maintain accountability and prevent brown bag breaks (review tool TBD).
    As for the kernel, I want to start by forking the official 2.6 kernel repo. Then my plan goes something like this:
    • Create a LS670-Froyo branch from the v2.6.32.9 tag.
    • Create a VM670-Froyo branch from the LS670-Froyo branch.
    • Create a LS670-Gingerbread branch from the v2.6.35.7 tag.
    • Create a VM670-Gingerbread branch by merging the VM670-Froyo changes.
    • Create an ics branch from v2.6.35.7 (?)
    • Add in "vanilla" project changes to the ics branch.
    • Merge changes across to LS670-Gingerbread and VM670-Gingerbread.
    That should result in two distinct and maintainable kernels with full source control history. We can repeat with other variants if they require any specific changes.
    Any comments or suggestions? Did I forget anything?
    Bob, I'm pretty sure that you're the most prominent IHO kernel maintainer after blarf. I'm particularly interested in your opinion on the kernel strategy.
    02-19-2012 10:42 PM
  24. JerryScript's Avatar
    Sounds good to me! I'll do some research into github's signing off procedures for multi-contributor repositories. I believe they have a review method built in, I'll let you know what I find. I have some cleaning up and reorganizing to do on my box, but I should have time to research this.
    For anyone using Wubi:
    I'm going to have to ditch my W7 for now and go full Ubuntu on my PC, not enough space is created with the largest possible settings when installing Wubi to build ICS and maintain my other projects.
    Oh well, I can't actually tell you when the last time was that I logged into W7 for anything other than to watch Netflix.
    tdm likes this.
    02-20-2012 12:52 AM
  25. rukin5197's Avatar
    Can someone help me here? I'm stumped. Building ICS from BobZHome's git..
    Code:
    make: *** No rule to make target `vendor/cm/proprietary/lib/armeabi/libjackpal-androidterm3.so', needed by `out/target/product/thunderc/system/lib/libjackpal-androidterm3.so'.  Stop.
    I can't for the life of me find libjackpal-androidterm3.so anywhere..
    EDIT: Nevermind. Added in tdm's files that he provided.
    Seems to be working
    02-20-2012 01:33 AM
339 ... 1011121314
