03-01-2012 09:14 AM
339 ... 7891011 ...
tools
  1. tdm's Avatar
    Oh, also, does anyone have a good VM670 kernel based on 2.6.35? I see GingerKernel floating around on github and that's apparently what Drew uses. I'll probably use that unless someone has a better one.
    02-14-2012 06:36 PM
  2. rukin5197's Avatar
    Hmm.. could this help?
    02-14-2012 06:41 PM
  3. BobZhome's Avatar
    tdm, sound like your doing better than me...here is my logcat: shell@android:/ $ logcat --------- beginning of /dev/log/main I/cm ( 71 - Pastebin.com
    02-14-2012 07:16 PM
  4. tdm's Avatar
    I should have known Bob would be on top of that.
    Thx!
    02-14-2012 07:17 PM
  5. JerryScript's Avatar
    A quick look through Bob's pastebin, appears as if we only need to get gralloc loading and grab the proprietary ril blobs and libraries, and that should take care of half of those warnings/errors (once we figure out the proper implementation of each).
    For LG, there are diag libraries that are used for reasons other than their name implies, so you might try adding all of those as well, then if any success, begin to remove to isolate.
    For the camera, I have no idea if ICS will be backportable due to the library files required. We may need to port the current camera up to ICS.
    Having played around with ICS this past week on a friend's phone, I'm kinda partial to Gingerbread. ICS is great on tablets, but I'm not so sure it's the bridge between devices everyone hoped for.
    One rant: I hate the ICS task bar! </rant>
    02-15-2012 12:51 AM
  6. LeslieAnn's Avatar
    ICS scales just fine as far as I can tell.
    I kind of like it, it does some good things and runs quite well.
    This is ICS with Launcher Pro (before I did much with it).
    JerryScript likes this.
    02-15-2012 01:45 AM
  7. tdm's Avatar
    Making progress.
    The first issue I see is that init cannot find /system/etc/init.local.rc (which is referenced from /init.rc on the ramdisk). I didn't think that /system was mounted at the point the rc-files are parsed so I really don't know how his is reading it, but it does seem to be succeeding because there's no error in dmesg.
    GB init does "import" as a normal command so that eg. and import line in post-fs can reference files under /system. ICS init does "import" as a part of the parsing process. So that makes it clear why I was getting the import error on my build. I can only assume that lupohirp has done something to change/fix this back to the GB behavior in his build.
    In his system, the two mkdir's fail with r=-17, which looks like EEXIST. But in mine they succeed. Even stranger, I don't see how do_mkdir() in system/core/init/builtins.c can return EEXIST because it checks for that and then runs chmod(), which cannot return EEXIST.
    GB init does not check for an existing directory. ICS init does. Again, I can only assume that lupohirp reverted that.
    02-15-2012 12:55 PM
  8. CuriousNoob's Avatar
    Click to view quoted image
    That wallpaper. <3
    02-15-2012 01:53 PM
  9. LeoLawliet's Avatar
    I'm running an ICS alpha that has been floating around, that was meant for the Optimus S, but still works fine and with wifi, just no calls/txts/data. If it's anything like the progress you guys have made then I'm pretty excited
    Sent from my LG-VM670 running ICS Alpha Wifi-only using Tapatalk
    02-15-2012 02:00 PM
  10. tdm's Avatar
    Success! I got my build to boot and run on par with Drew's drop: wifi works, no service.
    Currently using Drew's kernel+modules and all of the proprietary libs from his drop. Everything else is built from source.
    I got past the init troubles by inlining the rc-files under /system/etc and removing "exec sysinit" (after observing that it tries to run /system/xbin/run-parts, which doesn't exist).
    rukin5197 and Anonymo like this.
    02-15-2012 02:33 PM
  11. rukin5197's Avatar
    Not very professional - but have you tried dirty flashing it? That's how they got SMS working.. also, hoe about incoming/outgoing calls?
    Sent from my Amazon Kindle Fire using Tapatalk
    02-15-2012 02:51 PM
  12. CuriousNoob's Avatar
    Lol, you made a typo like me.
    Calling is through Online wifi calling, correct? I saw it on CM7 when messing with settings.
    02-15-2012 02:57 PM
  13. rukin5197's Avatar
    Well, if you wanted to use a voip ..
    But tdm, I'm finally understanding you for once. I'm looking through the kernel to se any changes lupo made for hw accel.
    02-15-2012 04:28 PM
  14. tdm's Avatar
    Replaced some proprietary libs with the ones from IHO. So far I've been able to:
    • Place a call
    • Send SMS
    • Receive SMS
    • Pair with bluetooth speaker
    This is looking like it might be a daily driver soon...
    02-15-2012 05:01 PM
  15. rukin5197's Avatar
    • Place a call
    • Send SMS
    • Receive SMS
    That's already daily enough for me...
    Have you taken a crack at the ril?
    I believe that the Triumph is CDMA also, so can't we use their commits for getting data to work..?
    https://github.com/mantera/android_f...b2e89b22404365
    Masema likes this.
    02-15-2012 05:14 PM
  16. LeslieAnn's Avatar
    That wallpaper. <3
    Wallpaper
    It's actually a little busy in my opinion.
    02-15-2012 05:18 PM
  17. tdm's Avatar
    I believe the libs I copied are all related to the ril:
    libril.so libril-qc-1.so liboncrpc.so libdsm.so libqueue.so libdiag.so libauth.so libcm.so libnv.so libpbmlib.so libwms.so libmmgsdilib.so libgsdi_exp.so libgstk_exp.so libril-qcril-hook-oem.so liboem_rapi.so libsnd.so libqmi.so libdss.so
    Also copied these binaries:
    ami304d cnd qmuxd rild
    And 3G does work, just tested.
    a5pe4 and Masema like this.
    02-15-2012 05:23 PM
  18. mjs2011's Avatar
    • Place a call
    • Send SMS
    • Receive SMS
    woah! i haven't looked at this in a day or two. i can't believe the progress you've made. you will soon gain legendary status.
    02-15-2012 05:24 PM
  19. rukin5197's Avatar
    This kinda raises the question: What about all the work the other devs have done to get ICS on there... lol will this stop further development from them.?
    02-15-2012 05:27 PM
  20. LeslieAnn's Avatar
    It's open source, everyone benefits.
    Now they can all move on to optimizing and making unique builds.
    drezliok, a5pe4 and cmerlyn like this.
    02-15-2012 05:33 PM
  21. JerryScript's Avatar
    @tim: Great work, I knew those libraries would be the difference! Any chance you might push your changes to your github?
    02-15-2012 06:07 PM
  22. tdm's Avatar
    Yes, I'll do that soon.
    We also need to figure out if this is going to be IHO or not.
    MrMACHOMAN86, Anonymo and Masema like this.
    02-15-2012 06:26 PM
  23. Eollie's Avatar
    Holy cow Jerry has dev status now!!
    a5pe4 and JerryScript like this.
    02-15-2012 06:28 PM
  24. a5pe4's Avatar
    Who would have thought our little V would get this far only a few days after it's birthday? A BIG thanks goes out to all our devs
    elisa9047 likes this.
    02-15-2012 06:30 PM
  25. flapjack.fiasco's Avatar
    When testers are needed, I'm so game!
    Sent from my Optimus V on Harmonia 2.
    02-15-2012 06:35 PM
339 ... 7891011 ...
