1. branden.lee's Avatar
    i tried cm7 and i didnt like it very much i wanna try to use the reborn ROM but when i go to install it in boot recovery it says installation aborted. is it my recovery img? some one please respond..
    12-10-2011 10:17 PM
  2. CuriousNoob's Avatar
    More info plz.
    What recovery are you using? Also, maybe try redownloading.
    12-11-2011 03:49 AM
  3. branden.lee's Avatar
    im using the xonia i think and i tried the vms70recovery.img witch shoould i use and i tried it over 5-6 times please help
    12-11-2011 04:49 PM
  4. bigsupersquid's Avatar
    use xionia recovery.
    turn off signature verification and script asserts (under install zip menu)
    and check the md5 for the rom to make sure your download didn't get corrupted along the way.
    12-11-2011 06:40 PM
  5. branden.lee's Avatar
    i have done all of that as well and it still wont let me do anything it just keeps saying installation aborted... (((
    12-11-2011 07:12 PM
  6. branden.lee's Avatar
    it says "Please switch to Edify scripting (update-script and update binary) to create working zip???? help?
    12-11-2011 07:17 PM
  7. Takenover83's Avatar
    Use Xionia CWMA v1.2518.6 recovery. I think Harmonia needs the same recovery. You can find it in this thread.
    http://forums.androidcentral.com/opt...stom-roms.html
    Download "xionia_cwma_125186 flashable zip", and flash it in your current recovery.
    12-11-2011 07:47 PM
  8. branden.lee's Avatar
    waht should i use too flash it? i tried the GUI app? and nothing any other ideas?
    12-11-2011 08:06 PM
  9. Takenover83's Avatar
    Flash it in your current recovery.
    12-11-2011 08:19 PM
  10. branden.lee's Avatar
    i ended up using the backside IHO rom with green machine.. its a lil laggy and freezes but i guess it wil have too do unless you can point me in a better direction with a newer/better ROM for the lg optimus v
    12-11-2011 08:48 PM
  11. mdb122480's Avatar
    I just flashed the Reborn ROM today and am very impressed with it. But for some reason, I can't connect to any wireless networks. It just tries to connect, but ultimately can't establish a connection. It was working fine beforehand. Anyone have any ideas as to what could be wrong?
    01-21-2012 02:42 AM
  12. Badboytoast's Avatar
    @ mdb122480;;;; Where can I get this reborn rom, and what recovery are you using? Is your phone new screen or old screen?
    01-21-2012 04:17 AM
  13. Eollie's Avatar
    Reborn is a old rom that is no longer supported. Its based on 2.2.
    mdb122480 do yourself a favor and the others here at AC and either install Harmonia 1.7 or one of the IHO/CM7 variants. You will thank me later trust me.
    01-21-2012 08:06 AM
  14. CuriousNoob's Avatar
    ^What he said, and if its laggy, overclocking helps.
    01-21-2012 09:58 AM
  15. Badboytoast's Avatar
    Oh 2.2 thanks for the info!!!
    01-21-2012 04:48 PM
  16. jesse..wells95's Avatar
    Use the activate app and let it go all thr way through. It worked for me when I had that problem
    01-21-2012 10:56 PM
