anthonycr
Themer. You've seen them
I do believe that you did something wrong, when it says "flash_image" not found that means you are using an invalid command. Check this thread about how to do it correctly.
The reason why you get " no flash_image found" is because you tried to flash the recovery from ROM Manager. You don't have a flash_image.
You need to install one.
You need to read all the posts and links provided 2-3 times
All the information and download links you need have already been given.
Please pay attention to the details. There isn't any reason why you can't straighten out things and be running a custom ROM with all the information already given. There isn't any more information that can be given. You've got it all.
Thanks for all the help everyone! I got the backside iho rom and its great i love it. Wich governer is best for overclocking?
