1. PoisonStar's Avatar
    Hey so i installed and flashed [ROM] ICSandwich2.3.7 - Final Edition and after awhile a screen keeps popping up say that the launcher has stopped and it needs to force close. Can anyone help me with this problem?
    02-17-2012 05:11 PM
  2. rukin5197's Avatar
    Known issue for the launcher. Isn't very optimized for our phones..
    I would recommend just installing another launcher from the market.
    02-17-2012 05:13 PM
  3. JerryScript's Avatar
    Just to be sure you understand, that is a GIngerbread ROM with ICS launcher and icons built in. It is not ICS.
    thaunknownartist likes this.
    02-17-2012 11:13 PM
