02-23-2012 07:10 AM
28 12
tools
  1. A.I.'s Avatar
    Yes the fastboot method should work. It's a typical "last straw" flashing process but it is more guaranteed, if anyone can remember the G1 days. You can completely go back to stock that way, IF you're phone is of the older variety. Newer versions don't get to use fastboot.
    02-23-2012 12:46 AM
  2. EpicSilver's Avatar
    I have the newer optimus v... does that mean fastboot won't work on it?
    02-23-2012 05:48 AM
  3. clodfelterac's Avatar
    if you didnt already get them... flash these... after a full wipe of course... 1) flashimage2 2) xoniarecovery... the xonia isnt really an rar... i already unzipped it and extracted the .img for you... just "rename" and delete the .rar before flashing... ( i had to add it to get it to upload)... i hope this helps...
    02-23-2012 07:10 AM
28 12
