1. theexile1's Avatar
    i get an error (0) when trying to flash can someone point out what type of scripting and what to use and what not i didnt have this problem on my old phone???
    02-24-2012 01:13 AM
  2. Paul627g's Avatar
    Error (o) is unknown to my knowledge. It is definitely a script error or the zip file itself related, I've come across this before myself.
    02-24-2012 01:16 AM
  3. theexile1's Avatar
    im gona try all the script settings il post my results
    02-24-2012 01:19 AM
  4. riggerman's Avatar
    I've had this happen to me before. You're going to need to replace the update binary in the UOT file with the one from your ROM zip file(the one you used to flash it). The instructions for this are on the pickup page in the UOT Kitchen.
    02-24-2012 06:05 AM
  5. CuriousNoob's Avatar
    It has to be Type MTD by default, and Edify scripting. I asked Jerry about this, sbd I believe that's what he told me.
    02-24-2012 09:09 AM
  6. theexile1's Avatar
    kk will try it
    02-24-2012 09:20 AM
