07-11-2012 07:48 PM
31 12
tools
  1. soupvw's Avatar
    yes but the link says file was deleted.
    07-11-2012 01:49 AM
  2. Schlidel's Avatar
    I have that patch on my Box account lemme see if I can find it.
    Boom. https://www.box.com/shared/223257f013266f2f5074
    Let me know if that link works for you. I'm fairly confident that's the final revision of mrg666's fix.
    I'd also like to note that mrg666's later/latest roms incorporate this fix.
    Sent from my mirage'd OV.
    mrg666 likes this.
    07-11-2012 05:32 PM
  3. mrg666's Avatar
    Thanks! Yes, it is the final revision. I think I deleted the file when I was cleaning up the mediafire folder. Will you keep this file available or should I upload it again?
    07-11-2012 05:41 PM
  4. Schlidel's Avatar
    Thanks! Yes, it is the final revision. I think I deleted the file when I was cleaning up the mediafire folder. Will you keep this file available or should you upload it again?
    I don't know how long box will keep that link alive and I don't have any file hosting accounts besides box/dropbox.
    Have a place for it?
    07-11-2012 05:47 PM
  5. mrg666's Avatar
    Yep, I have restored the file in mediafire and corrected the download link in IHO thread.
    Schlidel likes this.
    07-11-2012 05:48 PM
  6. riggerman's Avatar
    I've had links posted from my box account for over a year and they're still active. I usually get between 20 and 35 hits a week.
    07-11-2012 07:48 PM
31 12
