03-08-2012 10:15 PM
88 1234
tools
  1. JerryScript's Avatar
    It looks like you borked the system folder when you made your changes. That's why it's better to use a decompiler like apkmanager instead of just using an archive manager like 7zip. I believe you can do it with just 7zip, but be sure you have everything set to "store" and you don't attempt to sign the frameworks-res.apk or the systemui.apk, you don't resign system files.
    If you do post something like this, please post it as a themed BACKside-IHO like the ICS themed version was at xda. Once you make significant changes to the workings of the ROM, or build from IHO source with whatever changes you like, then you can post your work as your ROM.
    Of course, you can always build from IHO source and post your own ROM as pure IHO as well!
    And there's still a need for an AOSP port, I'm sure a lot of people would love to see one for the OV!
    lilrob1213 likes this.
    03-06-2012 01:57 AM
  2. anthonycr's Avatar
    I don't know how he borked it, because I do that thing every time I flash your new builds, just hecaude I like to switch ouf some stuff and theme it up. I've never had a problem except one time when I switched the framework-res.apk from harmonia and put it into backside, but that was understandable.
    03-06-2012 06:26 AM
  3. anthonycr's Avatar
    here's my modded launcher if you still want it
    03-06-2012 09:39 AM
  4. cammykool's Avatar
    will someone point me on the right direction? iver browsed the biulding your own rom thread with getting nothinbg out of it how do ibuild a rom like that with all the drivers and such....
    03-06-2012 10:36 AM
  5. cammykool's Avatar
    alright i lkooked at both and its alot of gibberish aosp requires gelal stuff and i dont wanna brick any phoes with IHO witch is why i planned to start with basicilly a modded backside and move away from kit with bnevery build so in a month maby no traces of the orifional rom will be therewhat did i do to bork my system folder
    03-06-2012 10:44 AM
  6. cammykool's Avatar
    im gonna take my GB backup to a hacksaw with this tut maby ill have a good GracieMod posted bvy the end of the week
    [GUIDE] The Noobs Guide to Android ROM'ing - xda-developers
    and i will use jerrys post in the building your own rom theead if i could run ubuntu in a program like VMware there is no video/audo/wireless drivers for my actual hardware for ubuntu can i virtual macine it?
    03-06-2012 11:10 AM
  7. JerryScript's Avatar
    Use WiBu, it's an installer you use in Windows to set up a virtual partition with Ubuntu on it. If you mess up, it's a simple Windows uninstall, so there's really no way to bork your box.
    03-06-2012 01:57 PM
  8. cammykool's Avatar
    I've done that.. u can get online. Everything is bliated and sound doesn't work. No drivers
    03-06-2012 02:47 PM
  9. rukin5197's Avatar
    Are you sure you didn't go into the ubuntu recovery? Lol
    03-06-2012 03:12 PM
  10. JerryScript's Avatar
    I've honestly never heard of anyone having issues using WiBu, sorry you had troubles.
    03-06-2012 03:17 PM
  11. cammykool's Avatar
    so i cant run it in a virtual enviorment?
    03-06-2012 05:30 PM
  12. LeslieAnn's Avatar
    Yes you can. I did my older builds from my file server using Virtualbox with Ubuntu.
    03-06-2012 05:49 PM
  13. cammykool's Avatar
    i have VMware installed so do i just mount my phone to the program and type away
    this will be fun
    03-06-2012 06:00 PM
  14. cammykool's Avatar
    alright i gave it 40 gigs and a gig of ram. enough?
    03-06-2012 06:10 PM
  15. BobZhome's Avatar
    I have 60GB and 1.6GB of ram for my VMware set up...it take 3 1/2 hours to compile CM7 and 6 hours for CM9
    rukin5197 likes this.
    03-06-2012 06:35 PM
  16. rukin5197's Avatar
    I got ~100gb and ~1.5 gb RAM (disk partition(dual booting)). Haven't necessarily tested build time because I usually let it run while I'm asleep. I can't believe you devs watch the whole thing. Lol soooo much code..
    03-06-2012 06:42 PM
  17. cammykool's Avatar
    when instyalling the JDk via get-install i seee this
    Code:
    root@ubuntu:~# apt-get install sun-java6-jdk sun-java6-jre
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package sun-java6-jdk is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package sun-java6-jdk has no installation candidate
    03-06-2012 06:44 PM
  18. pbailey212's Avatar
    Make sure you have it set for dual core processing, I don't think the free vmware lets you use more than dual, but by defaultits set for single core
    03-06-2012 06:48 PM
  19. cammykool's Avatar
    i have a amd althilon x2 its duyal ore
    03-06-2012 06:58 PM
  20. cammykool's Avatar
    i got some error about locked memory in vmware
    03-06-2012 07:02 PM
  21. cammykool's Avatar
    got it fixed but jdk still wont go
    03-06-2012 07:13 PM
  22. rukin5197's Avatar
    As long as you installed the right repo, go into synaptic package manager and do a search for it and install it there.
    03-06-2012 07:14 PM
  23. cammykool's Avatar
    repo?
    all i did was give myself root acess ebter "apt-cache search jdk" and then "apt-get install sun-java6-jdk sun-java6-jre" thats what gives me the rror
    03-06-2012 07:19 PM
  24. rukin5197's Avatar
    I think you may need to find a ppa. That's how I always do it. Try the one in Jerry's post in the Building your own ROM thread.
    03-06-2012 07:36 PM
  25. cammykool's Avatar
    fixed with
    Code:
    sudo add-apt-repository ppa:webupd8team/java
    sudo apt-get update
    sudo apt-get install oracle-jdk7-installer
    03-06-2012 07:40 PM
88 1234
