- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
- Virgin Mobile Optimus V
- Optimus V Rooting, ROMs, and Hacks
ROMs for longest battery life?
- I tested using 1x for about half a day to see if it improved battery life, it doesn't. If anything, it gets worse. The drain level is still the same (1% per hour if you aren't doing anything and aren't in an area with poor reception), but actually trying to do something just takes longer. It seems like keeping the screen on is what kills battery the most for me.
I've had a low of 2 hours, high of 36, been using Harmonia 2 for about a month now.03-20-2012 11:36 AMLike 0 - I tested using 1x for about half a day to see if it improved battery life, it doesn't. If anything, it gets worse. The drain level is still the same (1% per hour if you aren't doing anything and aren't in an area with poor reception), but actually trying to do something just takes longer. It seems like keeping the screen on is what kills battery the most for me.
Look into the Anker batteries on Ebay, you can pick up another 15-20% from that for about $10.
Harmonia 1 will give you even longer battery (probably the longest of any rom), but like I said, you are nearing the hardware's minimum needed to keep running.03-20-2012 08:51 PMLike 0 - bjzappWhere did u hear tht word1-1.5% per hour is the lowest you can ever get it, the hardware simply needs x amount to run.
Are you referring to the 1600 or 3200 mAh version?
obviously the 1600 is like 9 bucks.03-21-2012 03:59 PMLike 0
- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
