1. locogod's Avatar
    Ov is stuck on LG screen can`t go to recovery or boot up past that
    03-18-2012 09:33 PM
  2. CuriousNoob's Avatar
    What did you do exactly?
    03-18-2012 09:34 PM
  3. locogod's Avatar
    flashed the patched vm9 radio update
    03-18-2012 09:37 PM
  4. LeslieAnn's Avatar
    If it was the patch I posted, you have other issues.
    It is pretty much impossible for my patch to brick the phone as you describe.
    At worst it can stop the phone from calling or receiving data, but should not be capable of causing the phone to not boot.
    03-18-2012 09:44 PM
  5. locogod's Avatar
    All i did was enter recovery flashed patch to phone than it said installation complete than i clicked reboot system
    after it was on lg screen for more than a minute running harmonia 2.04 on CWMT Recovery
    03-18-2012 09:50 PM
  6. LeslieAnn's Avatar
    I almost wonder if that recovery may have had something to do with it.
    Do a battery pull and then give it a few to see if it passes that spot.
    03-18-2012 09:53 PM
  7. CuriousNoob's Avatar
    That recovery, isn't it from Rom Manager?
    03-18-2012 09:57 PM
  8. Teh_Gaberz's Avatar
    I'm having the exact same issue, and I am using the same recovery. Flashed the patch from recovery, rebooted, and now it's stuck at the boot logo. Did a few battery pulls and nothing. Tried going into recovery using power + home + volume down and can't even get into recovery.
    03-18-2012 09:58 PM
  9. locogod's Avatar
    03-18-2012 09:59 PM
  10. Discovered's Avatar
    No, but that's why I don't use it, its not 100 % ready for anything. It probably is because of the recovery.
    Sent from my LG-VM670 using Tapatalk 2 Beta-2
    03-18-2012 09:59 PM
  11. locogod's Avatar
    do you have adb access cause i don`t
    03-18-2012 10:38 PM
  12. CuriousNoob's Avatar
    That recovery was ported from CWM originally to work on the S....
    03-19-2012 12:08 AM
