1. theexile1's Avatar
    How do i make the apks smaller like size and actual picctures and stuff.
    such as making a hdpi app mdpi. trying to convert a theme i found.
    03-29-2012 12:51 AM
  2. JerryScript's Avatar
    If you just want to change the image sizes, open the apk with 7-zip or another good archive prog, but do not extract it, just open it. Then swap out the images you need to with their smaller conversions. Close the file, and resign it, then install.
    03-29-2012 12:59 AM
  3. anthonycr's Avatar
    Be careful with .9.pngs... I hate them stretchy pictures
    Sent from my VM670 using Tapatalk
    03-29-2012 01:01 AM
  4. theexile1's Avatar
    can i remove the hdpi and xdpi folders which wone can be removed
    03-29-2012 01:05 AM
  5. anthonycr's Avatar
    Remove all the pngs inside those folders... provided there's an mdpi folder
    03-29-2012 01:08 AM
  6. theexile1's Avatar
    alright got it then when can i replace files from another theme without editing the xml
    03-29-2012 01:10 AM
  7. JerryScript's Avatar
    So long as you maintain the same file names, you don't have to edit the xml.
    03-29-2012 02:04 AM
  8. EarthnFire78's Avatar
    Should clarify that those png in one folder can only be removed if there is a png of the same name in another folder. Some png's like the ones in the SystemUi.apk and Framework-res.apk can only be re-sized to a point while others the xml does the re-sizing if needed.
    03-29-2012 02:47 AM
  9. theexile1's Avatar
    im trying to change the blue color of ics and make it red any tips with xml editing
    03-29-2012 12:13 PM
  10. anthonycr's Avatar
    Well you need to change the color of the text... I suggest decompiling the framework-res.apk so you can edit the text xmls. Most of the stuff you want to change is really just pngs, like what jerry, earthnfire, and I mentioned before.
    03-29-2012 12:19 PM
