06-12-2012 10:23 AM
222 ... 34567 ...
tools
  1. BackHandLegend's Avatar
    I wish you guys luck I really do lol. I've tried many many things such as decompiling the framework and all. :P
    06-04-2012 11:08 PM
  2. Badboytoast's Avatar
    that's video is....... amazing!
    This is a dream port! This rom is good but this new one has more options!!! Good luck!
    06-04-2012 11:34 PM
  3. Nate456's Avatar
    Who would do this to a Android!?!
    ETA's kill puppies. Sent from a ______ with Tapatalk
    06-05-2012 12:05 AM
  4. Badboytoast's Avatar
    Me +1
    06-05-2012 12:31 AM
  5. ThatGuyLurkin's Avatar
    Ok guys. I was playing Skyrim ALOT. I slacked. I'm sorry. Ill do it when I get home from school.
    Badboytoast likes this.
    06-05-2012 12:58 AM
  6. BackHandLegend's Avatar
    oOoOoOoOoOo, deodexed, you guys know what that means? RACE TO PORT THE ROM. GO!!!
    06-05-2012 03:23 AM
  7. BackHandLegend's Avatar
    Gave it a go, after decompiling the framework, inserting the cdmasmsdispatcher into the other framework, porting over the framework, media, and app folders, and replacing the libsq pieces and libandroidruntime... I got phone FC spam...
    (Just giving a report here to show that I am still interested in this as many people)
    06-05-2012 04:07 AM
  8. ThatGuyLurkin's Avatar
    Actually, your supposed to replace the whole cdma folder.
    06-05-2012 07:44 AM
  9. anthonycr's Avatar
    I want this so I can laugh at iPhone toting hipsters and show them my iAndroid. I personally don't care for iOS but this will just make everyone stop and stare at it.
    06-05-2012 07:54 AM
  10. Badboytoast's Avatar
    Has anyone made it to the Finnish line!
    06-05-2012 11:16 AM
  11. xxlemonxx's Avatar
    I hopee
    06-05-2012 02:14 PM
  12. anthonycr's Avatar
    I just downloaded the zip to try to play around with it... its only 23 MB though... not a full rom?
    06-05-2012 02:27 PM
  13. Badboytoast's Avatar
    What do you mean not a full rom?
    06-05-2012 02:37 PM
  14. bornagainpenguin's Avatar
    Someone who wants to take the **** out of their iPhone using friends, that's who!
    Sent from my NookColor using Tapatalk 2
    06-05-2012 02:49 PM
  15. Nate456's Avatar
    True, true
    ETA's kill puppies. So please stop asking for ETA's.
    06-05-2012 02:54 PM
  16. ThatGuyLurkin's Avatar
    I just hot home. Expect a port with MMS and all within 4PM Eastern time
    06-05-2012 03:12 PM
  17. Badboytoast's Avatar
    !!!YES 4? min left this thread got me hook like the ics thread!!! Before an update
    06-05-2012 03:27 PM
  18. anthonycr's Avatar
    I downloaded the the rom in the post from a couple pages ago and got a zip file 23 MB... no rom fits in that size.
    Edit: it might not have downloaded correctly.
    06-05-2012 03:43 PM
  19. ThatGuyLurkin's Avatar
    Ok guys. I just finished a port. I'm testing it now, but I'm going to upload it anyways.
    BTW! 4PM is now.
    06-05-2012 04:00 PM
  20. ThatGuyLurkin's Avatar
    Ok guys, Download here, MMS should be just fine. As I type this, mine just flashed. Lets hope it boots.
    https://www.box.com/s/66ddaccf4669910d9460
    Edit: Bootanimation IS Black. It's a bad bootanimation.
    Update: Boots, Chinese text here and there. I'm gonna try removing some apps and add more IOS apps. Btw guys, the JOY OS apps work on CM7. The LAuncher, Gallery, Camera, MMS.apk. All those work on default CM7.
    Badboytoast and anthonycr like this.
    06-05-2012 04:06 PM
  21. Badboytoast's Avatar
    Phone die and just now getting a charge , downloading and flashing will report back
    06-05-2012 05:06 PM
  22. BackHandLegend's Avatar
    -MMS isn't working
    -Letters glitch in statusbar
    D;
    06-05-2012 06:23 PM
  23. ThatGuyLurkin's Avatar
    To do :
    •Use that RE that's on there and delete all the untranslated apps. Reboot. That'll fix the txt. MMS worked for me :/. Ill look into it.
    Also: VM turned my phone off for some reason. I sent back the replacement but they didn't believe me. So I can't test MMS and 3G.
    06-05-2012 07:12 PM
  24. anthonycr's Avatar
    -MMS isn't working
    D;
    it works for me... just sent two picture messages
    06-05-2012 07:14 PM
  25. BackHandLegend's Avatar
    Do you receive them?
    06-05-2012 07:49 PM
222 ... 34567 ...
