06-12-2012 10:23 AM
222 ... 56789
tools
  1. Badboytoast's Avatar
    We could use an mms.zip fix like the one for M
    06-06-2012 09:50 PM
  2. Badboytoast's Avatar
    @Thatguylurkin please help BHL with mms p....l.......e......a.......se
    You got it to work on your port!!!
    06-06-2012 10:00 PM
  3. xxlemonxx's Avatar
    I dont even really need MMS at the moment i got my email... But could you upload the the zip you have now? :O
    06-06-2012 10:11 PM
  4. ThatGuyLurkin's Avatar
    PM me if you need help fixing MMS
    Badboytoast likes this.
    06-06-2012 10:12 PM
  5. sammyz's Avatar
    Sammy nice to see you here!
    Yea I posted those screenshots:
    06-06-2012 10:13 PM
  6. sammyz's Avatar
    I don't we have a flashable fix
    topdawg661 likes this.
    06-06-2012 10:20 PM
  7. ThatGuyLurkin's Avatar
    I meant VM people.
    Im gonna take the newest port for G ace, remove apps, and swap with actual Joy OS ones. Maybe by Friday. Im busy with graduation
    06-06-2012 10:29 PM
  8. Badboytoast's Avatar
    Thank you ill keep an eye on this thread. 2 more days to go!!! Friday hopefully is the day!
    Edit: I do need mms!!!!
    06-06-2012 10:45 PM
  9. andrewnelson23's Avatar
    Wait, so the one that ThatGuyLurkin put up is working fully? mms and everything? Also, has anyone tried the GO mms fix???? I saw somebody asked it earlier but I don't think anyone tried it or reported. This looks like a really cool rom, but I'd rather not lose mms. Sooooo yeah. Please clarify everything atm. There are 3 versions of this rom?
    06-06-2012 11:48 PM
  10. BackHandLegend's Avatar
    OH I HAVE A GREAT IDEA. We should make a new thread with the 3 versions of iOS, just like the ICS
    06-06-2012 11:56 PM
  11. Badboytoast's Avatar
    Yes please do this you and him take the first three post!! That would be cool IOS flavor!!
    06-07-2012 12:07 AM
  12. ThatGuyLurkin's Avatar
    PM me the link of the one you want me to fix. Ill also replace some .apks for the better IOS look. iLauncher is crap
    Btw, im still working on LiGux BackHand
    06-07-2012 12:33 AM
  13. andrewnelson23's Avatar
    I like this a lot! I tried out ThatGuyLurkin's and I like it. Just a couple ui things. lots of stuff is still in chinese. I didn't know if that's being worked on, but this might help someone fix all that. I don't know what I'm doing, so I can't And then the only other hiccup I had was the fact that my phone has some weird writing in the background. I thought it was background, but it's still there when I pull up apps or my notification bar. I tried rebooting and when that didn't work, reflashing. here's a picture.
    EDIT: I just found out that if I touch the letters, I can move them around??? what on earth.
    06-07-2012 12:37 AM
  14. BackHandLegend's Avatar
    It's gone MADDDDDDDDDDDDDD!
    06-07-2012 01:13 AM
  15. andrewnelson23's Avatar
    Oh found out the weird little writing was a data monitor hahah just uninstalled it and the little numbers went away. Also, I uninstalled the ime. it got rid of the chinese keyboard. but since the play store doesn't work, i can't install a new keyboard :P hahah I'm gonna restore cold as ice. I can't wait til this is done!!! this looks so awesome
    06-07-2012 01:33 AM
  16. ThatGuyLurkin's Avatar
    Yes. Yse root explorer that was on there, delete all the Chinese apps.
    06-07-2012 07:38 AM
  17. xxlemonxx's Avatar
    I just want one without the bloatware and iOS statusbar
    06-07-2012 10:23 AM
  18. Badboytoast's Avatar
    You can delete the apps you don't want, but we do need a more English on this rom!
    andrewnelson23 likes this.
    06-07-2012 10:51 AM
  19. andrewnelson23's Avatar
    Well the system seems to be set in chinese. whenever I would long press items in order to delete, it would give me chinese options. Also, without Google play working, it's a no-go. What's the problem with the Play store?
    06-07-2012 11:15 AM
  20. Badboytoast's Avatar
    Have you try rebooting it 10 time might do the trick
    06-07-2012 11:19 AM
  21. andrewnelson23's Avatar
    I did better! I uninstalled the play store and reinstalled it from an apk I found online. still didn't work
    06-07-2012 11:30 AM
  22. xxlemonxx's Avatar
    Bhl upload without mms
    06-07-2012 11:40 AM
  23. sammyz's Avatar
    can anyone fix the play store? it was working for me, but then I rebooted and now it Force closes....
    06-07-2012 11:50 AM
  24. BackHandLegend's Avatar
    iDroid_port.zip
    Remember It's not finished guys. Have fun!
    06-07-2012 02:52 PM
  25. xxlemonxx's Avatar
    Does it have iOS statisbar
    06-07-2012 03:44 PM
222 ... 56789
