06-12-2012 09:23 AM
222 ... 6789
tools
  1. BackHandLegend's Avatar
    Check out the screenshots in the second post
    06-07-2012 02:49 PM
  2. Badboytoast's Avatar
    Is this your first Idroid port? Or the newest one with the status bar tricks?
    06-07-2012 03:32 PM
  3. BackHandLegend's Avatar
    Status bar tricks? I'm not sure what you mean.
    Badboytoast likes this.
    06-07-2012 04:55 PM
  4. xxlemonxx's Avatar
    Does it have the white status bar
    06-07-2012 04:59 PM
  5. BackHandLegend's Avatar
    Not this one, however there are cm7 themes.
    06-07-2012 05:01 PM
  6. xxlemonxx's Avatar
    I thought you said it did :O
    06-07-2012 05:18 PM
  7. andrewnelson23's Avatar
    iDroid_port.zip
    Remember It's not finished guys. Have fun!
    What works and what doesn't?
    Specific questions:
    Does play store work?
    Does mms work?
    Is there Chinese writing?
    06-07-2012 06:00 PM
  8. andrewnelson23's Avatar
    I tried it out. I like it a lot! It does have room for development, but I like it Is this the latest joyos version?
    06-07-2012 09:18 PM
  9. xxlemonxx's Avatar
    Everything work?
    06-07-2012 09:25 PM
  10. Badboytoast's Avatar
    Could you post some scream shoots plz
    06-07-2012 09:43 PM
  11. ThatGuyLurkin's Avatar
    Guys guys!
    Just make a backup, flash, test, flash back.
    06-07-2012 09:45 PM
  12. andrewnelson23's Avatar
    Well, I'm not entirely sure. I have bad service in my home so I can never get data connection or mms. So I can't say anything about the internet or mms. I think they'd proly work though.
    I've noticed a few things:
    First, the phone does not have a lot of the JoyOS apps, so that could be increased on.
    Second, holding home down crashes the rom.
    Third, there is some lag, but overclocking seems to fix it.
    Fourth, voice search does not work. Fixed by deleting by TB and reinstalling using the Play store.
    Fifth, there are some instances with the chinese text, but much, much less than ThatGuyLurkings.
    Sixth, in comparison to ThatGuyLurking's, I'd say they're about even. ThatGuyLurking's OS feels much more like the iOS than this one, but this one's performance bests ThatGuyLurking's.
    06-07-2012 09:58 PM
  13. andrewnelson23's Avatar
    Guys guys!
    Hey TGL, do you have any ideas on why the Market wasn't working on your port of it? Also perhaps you could use the language changes from BackHandLegend's port to stop all the chinese? I don't know, I have no idea when it comes to developing.
    06-07-2012 10:04 PM
  14. BackHandLegend's Avatar
    WHOA WHOA lol guys the details were in the second post -__-
    Anyway no, mms doesn't work, this isn't the latest JoyOS (which doesn't really matter I mean you get no new things other than the JoyOS app store which is pointless) and yes 3G works IF YOU HAVE READ THE SECOND PAGE!!!!!!!!! :3
    06-07-2012 10:06 PM
  15. BackHandLegend's Avatar
    I ported another version from the forums someone posted of the samsung phone, that one did have the white statusbar, however when I ported it I kept getting phone FCs. I tried many things to fix it, but nothing worked. So I'm going to be spending more time on the version I uploaded.
    06-07-2012 10:10 PM
  16. andrewnelson23's Avatar
    Hahah in the second page? Oh man. You know these forums. It sucks to read every post. Usually I just read the first two or three and then only really recent ones. ANYWAYS. This might help you fix the mms on your port: http://androidforums.com/optimus-v-a...rted-roms.html
    06-07-2012 10:20 PM
  17. Badboytoast's Avatar
    @BHL ohhhh cool just want to make sure since my 3g is acting and wont let me download it lol but yes your I Droid port is very stable except for mms, glade to hear that your going to keep on working on the idroid ill keep an eye on this thread and hopefully the new thread ios 3!!
    @ TGL its almost Friday your rom is also stable with mms but the language in setting options are in Chinese and Google play is not working
    @ both of you guys........Thank you guys!!!! very cool experience ios on my ov
    Don't give up! We thank ya!
    andrewnelson23 likes this.
    06-07-2012 10:33 PM
  18. ThatGuyLurkin's Avatar
    Jesus. Alot of stuff. Dude, its a port. :P
    Ill make a better build later. Chinese txt will be there no matter what. Its made by Asian Devs.
    JoyOS.cn
    06-07-2012 10:33 PM
  19. BackHandLegend's Avatar
    Hmmm, I've done the thing with Framework.jar, but not Framework-res or whatever. I'll try it now and test okay?
    06-07-2012 10:37 PM
  20. BackHandLegend's Avatar
    No cigar! D;
    06-07-2012 11:01 PM
  21. andrewnelson23's Avatar
    I saw that CN said he might make a guide on how to do it with framework.jar. He said Gingerbread roms mms is contained in the framework.jar, not the framework-res(which is where mms is at on ics roms). So that makes sense that it wouldn't work for you for the framework-res, cuz this is a gb rom. So hopefully CN will post how to fix mms from the framework.jar.
    06-07-2012 11:18 PM
  22. BackHandLegend's Avatar
    I already know how to do that, I've tried. But don't worry I still have many things to try.
    06-07-2012 11:51 PM
  23. Badboytoast's Avatar
    Check this out
    Rom: ThatguyLurking
    Setting are still in Chinese
    06-08-2012 02:18 AM
  24. xxlemonxx's Avatar
    Any update?(:
    06-08-2012 06:38 PM
  25. bornagainpenguin's Avatar
    Check this out
    Rom: ThatguyLurking
    So.... Any chance you'll be releasing this soon?
    Sent from my NookColor using Tapatalk 2
    06-09-2012 11:14 AM
222 ... 6789
