Porting help.
ThatGuyLurkin
2,155
665
To do :
•Use that RE that's on there and delete all the untranslated apps. Reboot. That'll fix the txt. MMS worked for me :/. Ill look into it.
Also: VM turned my phone off for some reason. I sent back the replacement but they didn't believe me. So I can't test MMS and 3G. :(
xxlemonxx
254
29
Has so much bloatware and apps i cant uninstall and randon net monitor.. Locksceen isnt even that good. And on top of that the status bar isnt even iphone ish :O Video was a lie..
xxlemonxx
254
29
I still appreciate the work :D The triangle at the top right is annoying me D: i wish the orignal one had the ios status bar and fully working 3g
Badboytoast
820
122
same here! lurking rom is really cool i did some changes on the settings and i got.it looking cool but i notice that i cant use google play?
be1digital
