1. slutyman321's Avatar
    can someone edit the harmonia 2.05 build prop to get it working on metro pcs i have a rom almost fully running and all i need is to edit the build prop change cdma carrier ID and numeric to whatever Metro uses will pay at least 20 bucks if someone does this
    04-13-2012 09:28 PM
  2. kcls's Avatar
    I thought that was illegal now?
    04-13-2012 09:29 PM
  3. anthonycr's Avatar
    Ro.cdma.home.operator.numeric=310120
    For metro pcs
    But like kcls is saying... it may be illegal.
    04-13-2012 09:36 PM
  4. slutyman321's Avatar
    is that all i have to edit i have notice that the rest said virgin mobile gsm what do i do about that
    04-13-2012 09:39 PM
  5. LeslieAnn's Avatar
    It is not illegal.
    The new law is a bill PROPOSAL.
    Even then, it really changes nothing, the original alaw says you cannot change the numbers to avoid the new database. The old law states you cannot change it in order to commit fraud. Not only is the new law pretty pointless as it would be fraud to bypass the new database anyhow, but the original said it was illegal to do so in order to commit fraud, which is illegal anyhow.
    An OV on Metro is not committing fraud, you are simply putting a different phone onto their system, which you are paying to access.
    04-13-2012 09:57 PM
  6. LeslieAnn's Avatar
    You have to change the part right next to it that says Virgin as well as the actual number.
    04-13-2012 10:00 PM
  7. slutyman321's Avatar
    so is that all i had to edit or is there more because i found a .zip to get mms working for gb all i need is the internet now
    04-13-2012 10:01 PM
  8. LeslieAnn's Avatar
    Depends on what is in the zip.
    04-13-2012 10:09 PM
  9. slutyman321's Avatar
    the zip is for mms only but the internet is what i need now is it all in the apn or can you do i will pay 20 bucks if you do
    04-13-2012 10:11 PM
  10. anthonycr's Avatar
    I have to say this... $20 your willing to fork out to get this fixed + $50 you could probably get for your OV on ebay = $70 which is probably about what you would have to pay for a used Optimus M.
    Idk why you are trying to kill yourself here.
    Sent from my VM670 using Tapatalk 2
    04-13-2012 10:22 PM
  11. slutyman321's Avatar
    naa im good so is that all i had to edit in the build prop
    04-13-2012 10:40 PM
  12. MidtownHD's Avatar
    I must say that our OV has the best overall design compared to other variants.
    04-13-2012 10:48 PM
  13. slutyman321's Avatar
    so im i good now for internet and mms and talk and text
    04-13-2012 10:59 PM
  14. Badboytoast's Avatar
    Could you pm me the mms.zip please I would like to test it!
    04-13-2012 11:32 PM
  15. slutyman321's Avatar
    does someone want to help me make a rom just for a flashed optimus v metro pcs
    Badboytoast likes this.
    04-13-2012 11:40 PM
