1. CloudBusterr's Avatar
    I installed MIUI a couple days ago and the first day I used it, the ROM ran fine. But today, I unplugged my phone at 5:30am and it died at about 1pm. I had 3G on and my screen on for maybe 30 minutes. I know my battery shouldn't be dying this fast. Is anybody else having this problem?
    04-17-2012 02:16 PM
  2. tonylipscomb's Avatar
    I'm experiencing the same issues. Its almost like its not charging. May have something to do with overclocking on my end. I'm not sure doing more test tonight.
    04-17-2012 07:49 PM
  3. CuriousNoob's Avatar
    That's odd. I unplug about 7am, and I always have Wifi on, and right now, I have 30% left.
    One thing I know is that it's the themes take up usage as well.
    04-17-2012 08:02 PM
  4. CloudBusterr's Avatar
    Hmmm... I applied a theme yesterday. I'm overclocked to 480 and 787. Nothing out of the ordinary for my phone.
    It might be the theme
    04-17-2012 08:21 PM
  5. CuriousNoob's Avatar
    I'm on default overclock. I can't stay stable at 600+. Barrly 600. Random reboots every 20 minutes.
    Sent from my LG-VM670 using Tapatalk 2 Beta-5
    04-18-2012 06:39 AM
  6. CloudBusterr's Avatar
    :O that must suck. I can stably go to 864 but it probably kills my battery
    04-18-2012 12:45 PM
  7. DKGerbil2's Avatar
    Any reason this isn't in the MIUI thread? This is pretty specific.
    Do you have any reason to believe that this isn't normal behavior? You said yourself that 3G was on 7 hours.
    04-18-2012 12:58 PM
  8. CloudBusterr's Avatar
    I said that I had my 3G on for 30 minutes out of those seven hours.
    04-18-2012 01:46 PM
  9. CuriousNoob's Avatar
    On my old Optimus, I went 3 days with Minimal usage, thanks to the beach, overclocked at 600 - 844.
    04-18-2012 02:30 PM
  10. DKGerbil2's Avatar
    Your wording makes it seem like your 3G was on the entire time but your screen was only on for 30 minutes. Either way, it's a buggy ROM that still has issues to work out, what were you expecting? Have you reset the battery stats or anything?
    04-18-2012 04:57 PM
