I want this on my s
Sent from my LS670 using Tapatalk 2
I can try this later
I want this on my s
I will see what i can doYou will????
If you will can you make it for our new update zvj?
Ginger rom
808mhz
8gb sdcard
Amphetimas
Hydro Kernel
Sent from my LG-VM670 using Tapatalk 2 Beta-5
But im going to need some.tester because idont have a working optimus s
Just pm me with test roms and tell me what baseband I'm on zvd so if u make it for that it might be easier
Please Make it for zvd ok?
Ginger rom
808mhz
8gb sdcard
Amphetimas
Hydro Kernel
Ok i will base it of zvd then
Thanks I'm on zvj I will downgrade when do you plan to release
Ginger rom
808mhz
8gb sdcard
Amphetimas
Hydro Kernel
Ok i will probably send u the zip later this week and if it runs well i will release
I am hearing sense? Gannon has a booting sense. But the post was lost in the archives. I have the zip if you want it
Perfect thanks for your work
Time
And open mind
Ginger rom
808mhz
8gb sdcard
Amphetimas
Hydro Kernel
Want me to run a build of my rom and kernel for the optimus s?
