1. Sento's Avatar
    I hear overclocking can even help increase battery life, still trying to find the sweet spot
    ATM I am 245-787 MHz on demand
    What y'all recommend?
    04-25-2012 07:25 PM
  2. cole2kb's Avatar
    There are no good recommendations. It all depends on your specific phone, each batch of OV's is a little different.
    04-25-2012 07:47 PM
  3. CuriousNoob's Avatar
    I run Smartassv2 729-825. I have 23% left, running MIUI. Miui has a battery drain though. So ;P
    04-25-2012 07:50 PM
  4. Sento's Avatar
    Any recommendations for governor? When I use smartass, I drain like crazy...and phone doesn't charge.
    04-25-2012 07:51 PM
  5. LeslieAnn's Avatar
    The generic sweet spot is 480 for the minimum.
    There is little to be gained and lots to lose going lower or higher for the minimum.
    The high, as stated is dependent on your phone.
    Smartass2 seems the preferred setting.
    kenbrasensei likes this.
    04-25-2012 07:53 PM
