What i did was this.
1. I got the quatrimus rom from the other thread on here.
2.Unzipped it to my desktop (on my pc)
3. Pulled out the system/framework/framework_res.apk
4.changed the .apk extention to .zip and extracted it (to a separate folder on my desktop)
5.copied the framework_res.apk (on my phone via es file explorer)
6.pasted it into the root of my sd-card
7.plugged my phone to my pc and copied the framework_res.apk to my desktop (on my pc)
8.changed the .apk extention to .zip and extracted it (to a separate folder on my desktop)
9.took the eri.xml from the quatrimus rom i extracted earlier (in the res/xml directory)
10. put it into the extracted kraven res/xml folder (overwriting the existing eri.xml)
11. rezip the framework_res from the kraven rom
12. change the .zip extension back to .apk
13.and put it on your sd card (on your phone)
14 using esfile explorer transfer it to your system/framework directory (on your phone)
15. Your phone will ask you if you want to overwrite
16. click yes and then it will reboot automatically (at least mine did) then it is fixed.
There is also a easier way to get the file from your phone by pulling it via adb. But at the time I was doing this i didn't have the root enabled yet. That is todays task lol and another tutorial that i believe someone else already wrote somewhere on here.
Now there is probably a simpler way to edit the xml directly but i didnt know the line so i did it this way.
If you don't know how to change the extension of the files here are links for both win 7 and win xp......
for XP
How to Change a File Extension in Windows XP
for WIN 7
