Cold As Ice working on Optimus V!
kirurus
170
28
So? How did you accomplish that compared to the previous install? (Ya got me droolin', DeWd!)
No idea. I tried flashing everything at once last time. This time I booted after flashing ROM then gapps, then rebooted and flashed kernel and button fix that cole posted. Buuuuut, somewhere down the road I ran into a bootloop so I'm done playing with this. I'll be patient and wait for tdm to work his magic. The camera isn't that important to me and the MMS fix build posted on the quatrimmus thread works so I'm happy.
Reactions: glarepate
kirurus
170
28
Oh OK so wat governor should i use
Sent from my LS670 using Tapatalk 2
I like SmartassV2, but ondemand, interactive, interactivex, SavagedZen (similar to smartass) scary and msm7k will not lock the processor like that.
Here is a good thread that explains the different governors and how they control the processor. Other nice information in there as well.
[REF][TWEAKS] Kernel Governors, Modules, I/O Schedulers, CPU Tweaks, AIO App Configs - xda-developers
Usually performance is used when you are benchmarking your phone.
glarepate
85
11
I NEED A FIX FOR MMS!!! SOMEBODY PLEASE HELP ME!!!!
sent from my icy cold hydromus
Wasn't it something like ...
The fix that you're looking for is on page 72 but for the sake of convenience, I'll just quote it here.
MMS works just fine for me, I'm running on Alpha 7 though.
Quote:
Originally Posted by JerryScript View Post
You'll need to edit the apns-conf.xml to reflect Virgin Mobile's values 311 490
For anyone who wants to try:
- use a root capable file manager, and copy the /system/etc/apns-conf.xml file to your PC (it's too large to edit on the phone)
- open it with a good text editor (notepad may work, but I don't ever recommend notepad).
- search for Virgin Mobile US, and change the mcc to 311 and mnc to 490.
- copy it back to your phone,
- clear cache in the MMS app,
- reboot.
I forget ...
:p
Zakman
492
185
you can use the workaround:
Download Go SMS, Go to advanced settings>mms settings and tick use manual apn. enter MMSC as
Code:
http://mmsc.vmobl.com:8088/mms?
MMS Proxy as
Code:
205.239.233.136
and MMS port as
Code:
81
worked for me :))
Reactions: dbarker1344
konie06
11
the link for the Homekey fix is NOT WORKING. can you please updated a working link so i can continue with this download.. i mean seriously!!
Zhara
Queendroid
Apr 4, 2012
891
200
Seriously what? This rom isn't even for the OV, I think some of you need to be a little more appreciative that it even works on your phone at all. Good grief...all this rudeness is getting old.
Reactions: puffen619
lindagibney
