Downloading Now
Can you check that the keyswap and framework fix work with it?
I can confirm it works on 10G
cm9.a6.homekeyfix-1.zip
Is this the original fix posted here or is there a new one that needs to be used? The one I have is no longer available for download so I'm wondering if I need a new one because of that...well that and the name...
Code:cm9.a6.homekeyfix-1.zip
That's the one I have. The a6 part is what makes me nervous. I would think that would refer to an alpha version 6 unless someone can point me to something that says otherwise. Meanwhile I'm downloading the rest of the updated file now...
--bornagainpenguin
--bornagainpenguin
Here's the newest one, it's working for me with 10G:
cm9.a10.vmfix1.zip
From here, : http://forums.androidcentral.com/lg...70-5-6-zvd-basesband-alpha10.html#post1612822
Yeah that one is outdated, you should check the cold as ice thread more often for updates. Everything is there in the OP and yes use the fix that was posted, it should work.
