Cold As Ice working on Optimus V!
Nonnef
3
+1 for Clocksync, it's great. Not perfect, but makes things MUCH better.
What settings are you using for ClockSync? I've tried 30 second auto sync and every other option I could figure out and it hasn't seemed to make a difference.
Sent from my VM670 using Android Central Forums
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Auto-sync enabled, 30 minute intervals, high precision mode, sync on boot. If you're running AOSP, it might not work, last time I tried root access was broken, which Clocksync needs for automatic updating.
Reactions: Nonnef
LeoLawliet
713
108
Root access works fine on AOKP
Sent from my LG-E739 using Tapatalk 2
notown
SAMLOKA
Jun 2, 2011
367
67
i thought cam was fixed with the latest build. I could be wrong. Ill be flashing the latest CAI ROM later on tonight. Ill report back if any issues with that.
RyanJKremer
155
50
I have it set to 1-day intervals, automatic synchronization, and only when awake. I have had no issues since installing.
The clock-lag was almost a deal-breaker for me on all of the ics roms. This was an awesome find! Thanks again, rebel69ization!
Reactions: rebel69ization
pbailey212
765
219
Ugh! Mine doesn't Dx
U guys have Any idea why it doesn't ?
Check md5, wipe cache and dalvik flash again. If MD 5 matches and you wiped caches and it still doesn't work, try wiping everything and do a clean install, if that still doesn't work, do a logcat at the time its trying to connect, and pastbin it here
MarcosVo
