Way to test your charger: power on the phone, plug in charger, and remove battery. If your phone stays on (it should) your charger has juice.
Sometimes, you may just need to wiggle it. A power jack can be loose or bad soldering, but it isnt totally dead.
Sent from my VM670 using Tapatalk 2
